The RX70KMSFPST is a Juniper RX-FXSM-SFP compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-ZX compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Juniper RX-70KM-SFP Compatible SFP Module, 1000BASE-ZX, 1GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector 70km, 1550nm, DDM, Mini GBIC - Lifetime Warranty (RX70KMSFPST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-ZX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1550 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 70 km
- OEM Manufacturer Equivalent Part Number
- Juniper RX-FXSM-SFP
- 1.4 cm x 6.5 cm x 1.2 cm
- 72 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-ZX
- 1GbE
- 1 Gbps
- 1550 nm
- 70 km
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 1000Base-ZX - LC single-mode female x 2
- MTBF
- 53,972,659 hours
- FCC, RoHS, REACH, MSA
- 1.4 cm
- 6.5 cm
- 1.2 cm
- 72 g
- Shipping Width
- 20.7 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 80 g
- Limited warranty - lifetime
