The RX10KMSFPST is a Juniper RX-550M-SFP compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000BASE-LX compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Juniper RX-10KM-SFP Compatible SFP Module, 1000BASE-LX, 1GbE Single/Multi Mode MMF Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector 10km, 1310nm, DDM, Mini GBIC - Lifetime Warranty (RX10KMSFPST) - SFP (mini-GBIC) transceiver module - GigE
- SFP (mini-GBIC) transceiver module - LC single-mode / LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-LX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- GigE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Juniper RX-10KM-SFP
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-LX
- GigE
- 1 Gbps
- 1310 nm
- 10 km
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 1000Base-LX - LC single-mode / LC multi-mode female x 2
- MTBF
- 53,972,659 hours
- MSA
- Limited warranty - lifetime
