Brand
StarTech.com JD094B-BX60-D SFP+ Module - Lifetime Warranty - 10 Gbps
Quicklinx: FJMVWS00 Mfr#: JD094B-BX60-D-ST
£547.82 ex VAT
£657.38 inc VAT
The JD094B-BX60-D-ST is an HP JD094B-BX60-D compatible downstream fiber SFP+ transceiver which pairs with StarTech.com's JD094B-BX60-U-ST. They are designed, programmed and tested to work with 10GBase-BX compatible HP switches and routers. The SFP+ transceiver module supports a maximum distance of up to 60 km (37.3 mi) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ Cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com HPE JD094B-BX60-D Compatible SFP+ Module, 10GBASE-BX, 10 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP+, LC 60km, HPE 5900, 12500, 5500 Mini GBIC Transceiver - Lifetime Warranty (JD094B-BX60-D-ST) - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-BX
Data Transfer Rate
10 Gbps
Optical Wave Length
1270 nm / 1330 nm
10 GigE
Max Transfer Distance
60 km
HP JD094B-BX60-D
5.84 cm x 1.39 cm x 1.26 cm
24 g
HP A5830AF-48G; HPE 12504, 5120-48G-PoE+, 5500-24G-PoE+-4SFP, 5500-24G-SFP, 5500-48G-4SFP, 5810-48G, 5900AF-48G-4XG-2QSFP+, 5900AF-48XG-4QSFP+, 5900AF-48XGT-4QSFP+, 5920AF-24XG; FlexFabric 1.92, 11908-V, 12902E
Plug-in module
Wired
Cabling Type
10GBase-BX
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1270 nm / 1330 nm
60 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-BX - LC single-mode female
MSA
HP JD094B-BX60-D
5.84 cm
1.39 cm
1.26 cm
24 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
HP A5830AF-48G Switch , HPE 12504 AC Switch Chassis, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-PoE+-4SFP HI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 5810-48G Switch, 5900AF-48G-4XG-2QSFP+ Switch, 5900AF-48XG-4QSFP+ Switch, 5900AF-48XGT-4QSFP+ Switch, 5920AF-24XG Switch , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis, 12902E Switch Chassis
Price Range Ex VAT: £500 - £750
