Add 5 GHz Wi-Fi coverage to an outdoor area, with a ruggedized industrial access point - PoE Powered. The R300WN22MO5G Outdoor Wireless Access Point lets you add 5 GHz Wireless-N network coverage to an outdoor area, through a ruggedized industrial access point.
This outdoor access point features an IP67 certified, die-cast metal enclosure with heavy-duty cable grommets so it can withstand the outdoor elements and offers pole and wall-mounting options. Plus, the PoE-powered AP includes a passive Power-over-Ethernet injector, enabling you to install it in locations where a typical power outlet is unavailable. PoE pass-through via the secondary LAN port lets you connect data and power to a PoE-capable device near the access point.
By isolating your Wi-Fi network to the 5 GHz frequency, dual-band smartphones, tablets or laptops can operate with less interference from other devices than on the more common 2.4 GHz band. For optimal wireless coverage, the AP broadcasts a signal through a high-powered 800 mW internal 10 dBi 2T2R antenna.
The device offers support for several different operating modes, which help you to create a wireless network from a wired connection, bridge multiple APs together or extend the range of an existing wireless network. The AP supports Wireless-N data rates up to 300 Mbps with security through WEP, WPA, or WPA2 authentication, all configurable through an easy-to-use web-based utility.
- StarTech.com IP67 Certified 5GHz Outdoor Wireless-N Access Point - WiFi AP - radio access point
- Radio access point
- Form Factor
- External - outdoor
- Localisation
- United Kingdom
- Processor
- Atheros AR9342
- Data Link Protocol
- IEEE 802.11a, IEEE 802.11n
- Frequency Band
- 5 GHz
- Included Accessories
- PoE injector
- Power Over Ethernet (PoE) Supported
- PoE
- 9.6 cm x 15.8 cm x 4.9 cm
- 820 g
- 2-year warranty
- Ruggedized Design
- Outdoor
- 9.6 cm
- 15.8 cm
- 4.9 cm
- 820 g
- Enclosure Colour
- Grey
- Localisation
- United Kingdom
Processor / Memory / Storage
- Processors Installed
- Atheros AR9342
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- 64 QAM, BPSK, QPSK, 16 QAM, OFDM
- CSMA/CA
- Frequency Band
- 5 GHz
- Max Range Open Space
- 3.7 km
- Status Indicators
- Power, link/activity
- 2T2R MIMO technology
- Encryption Algorithm
- TKIP, WPA, WEP
- IEEE 802.3, IEEE 802.3u, IEEE 802.11a, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 1
- Gain Level
- 10 dBi
- 2 x - RJ-45
- PoE injector
- RoHS, IP67
- PoE
- Power Device
- External power adapter
- Limited warranty - 2 years
- -30 °C
- 60 °C
- 0 - 100% (non-condensing)
StarTech.com 1000ft Roll Gray Stranded Cat 6 Patch Cable | In Stock | £218.00 |
StarTech.com Outdoor 300 Mbps 2T2R Wireless-N Access Point - 5GHz 802.11a/n PoE-Powered WiFi AP | In Stock | £51.22 |
StarTech.com IP67 Certified 2.4GHz Outdoor Wireless-N Access Point -WiFi AP | In Stock | £125.27 |
StarTech.com IP67 Certified 2T2R 5GHz Outdoor Wireless-N Access Point - 300 Mbps WiFi AP | In Stock | £131.09 |
