StarTech.com IP67 Certified 2.4GHz Outdoor Wireless-N Access Point -WiFi AP
Quicklinx: 9YY4WS00 Mfr#: R300WN22ODG
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
£93.02 ex VAT
£111.62 inc VAT
Add 2.4 GHz Wi-Fi coverage to an outdoor area, with a ruggedized industrial access point - PoE Powered. The R300WN22ODG Outdoor Wireless Access Point lets you add 2.4 GHz Wireless-N network coverage to an outdoor area, through a ruggedized industrial access point.
This outdoor access point features an IP67 certified, die-cast metal enclosure with heavy-duty cable grommets so it can withstand the outdoor elements and offers pole and wall-mounting options. Plus, the PoE-powered AP includes a passive Power-over-Ethernet injector, enabling you to install it in locations where a typical power outlet is unavailable. PoE pass-through via the secondary LAN port lets you connect data and power to a PoE-capable device near the access point.
For optimal wireless coverage, the AP broadcasts a signal through a high-powered 800 mW internal 10 dBi 2T2R antenna, with 802.11b/g/n compatibility to easily connect most wireless devices new or old.
The device offers support for several different operating modes (AP, WDS and WISP), which help you to create a wireless network from a wired connection, bridge multiple APs together or extend the range of an existing wireless network. The AP supports Wireless-N data rates up to 300 Mbps with security through WEP, WPA, or WPA2 authentication, all configurable through an easy-to-use web-based utility.
StarTech.com IP67 Certified 2.4GHz Outdoor Wireless-N Access Point -WiFi AP - radio access point
Radio access point
External - outdoor
United Kingdom
Atheros AR9341
Frequency Band
2.4 GHz
PoE injector
Power Over Ethernet (PoE) Supported
PoE
9.6 cm x 15.8 cm x 4.9 cm
820 g
Radio access point
Ruggedized Design
Outdoor
9.6 cm
15.8 cm
4.9 cm
820 g
Enclosure Colour
Grey
United Kingdom
Processor / Memory / Storage
Processors Installed
Atheros AR9341
External
Wireless
Data Transfer Rate
300 Mbps
Spread Spectrum Method
OFDM, DSSS
Network / Transport Protocol
CSMA/CA
Frequency Band
2.4 GHz
Max Range Open Space
3.7 km
Status Indicators
Power, link/activity
2T2R MIMO technology
Encryption Algorithm
TKIP, WPA, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
1
Gain Level
10 dBi
2 x - RJ-45
PoE injector
RoHS, IP67
PoE
External power adapter
-30 °C
60 °C
0 - 100% (non-condensing)
9YY4 StarTech.com 1000ft Roll Gray Stranded Cat 6 Patch Cable In Stock £220.71
9YY4 StarTech.com IP67 Certified 2.4GHz Outdoor Wireless-N Access Point -WiFi AP In Stock £93.02
9YY4 StarTech.com IP67 Certified 2T2R 5GHz Outdoor Wireless-N Access Point - 300 Mbps WiFi AP In Stock £126.62
Speed: 300Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Price Range Ex VAT: 50 - 100
