StarTech.com Industrial Fiber to Ethernet Media Converter 100Mbps SFP
Quicklinx: G3QLWS00 Mfr#: IMC100MSFP
10 in stock
£94.45 ex VAT
£113.34 inc VAT
This media converter features an open SFP slot for any standard SFP to be used for the incoming fiber connection and is easily deployed across applications or fiber cable types. Accepts terminal block power or coaxial power connectors with the barrel plug adapter, allowing the product to be hardwired or powered using an external power supply (not included), which does not require professional installation. It can be powered using 18V-36V AC or 12V -56V DC for a high degree of flexibility including applications like solar, automotive, and rail. Includes hardware for DIN rail or wall mounting.
  • Compact size + flexible power input
    Smallest form factor Fiber to Ethernet media converter - extends & converts 100Mbps fiber to RJ45 copper; powered by 18-36V AC or 12V-56V DC for solar, auto & rail.
  • Robust design
    Industrial Network Media Converter with MTBF 500,000+hrs @ 50C. Vibration, shock & freefall rated. Rugged IP-30 aluminum housing. Hardened operating temp -40C to 75C.
  • Open SFP slot
    Compatible with any standard SFP and can be used for multimode or single mode fiber connections; easy deployment across applications, fiber distances or fiber cable types.
StarTech.com Industrial Fiber to Ethernet Media Converter - 100Mbps SFP to RJ45/Cat6 - Singlemode/Multimode Optical Fiber to Copper Network - 12-56V DC - IP-30/ -40 to +75C - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / SFP (mini-GBIC)
DIN rail mountable
Cabling Type
100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
10Mb LAN, 100Mb LAN
AC 18 - 36 V / DC 12 - 56 V
3.2 cm x 5.9 cm x 5 cm
81.4 g
DIN rail mountable
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Status Indicators
Port status, active, link
Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode, Back Pressure Support, 2KV Surge protection
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3x
1 x Ethernet 100Base-TX - RJ-45 female , 1 x Ethernet 100Base-FX - SFP female
Power terminal block
Mounting Kit
Included
MTBF
534,482 hours
IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, FCC, RoHS, EN 60950-1, WEEE, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6
External power adapter
1.92 Watt
3.2 cm
5.9 cm
5 cm
81.4 g
Shipping Width
15.5 cm
Shipping Depth
10.5 cm
Shipping Height
6.4 cm
Shipping Weight
200 g
-40 °C
75 °C
5 - 95% (non-condensing)
Stock Status: In stock
