StarTech.com Industrial 5Port Gigabit PoE+ Switch 30W
Quicklinx: G3QJWS00 Mfr#: IESC1G50UP
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: [N/A]
Managed: No
POE: PoE+
14 In Stock
£207.50 ex VAT
£249.00 inc VAT
This industrial 5-port gigabit PoE switch (4-port PoE) features 30W of power and is designed to be installed in harsh environments and supports up to a total of 120W power outputs.
  • Rugged design for harsh environments
    With a temperature range of -40°C to 75°C and high durability, this PoE switch is built to perform reliably in tough conditions.
  • High capacity for Power over Ethernet
    The switch supports a PoE budget of 120 W, enabling it to power various connected devices efficiently.
  • Versatile networking capabilities
    Featuring 5 ports with data rates of 10/100/1000 Mbps, the switch ensures fast and efficient data transfer for multiple applications.
  • Compliant with industry standards
    This switch meets standards such as RoHS and FCC, ensuring it adheres to safety and environmental requirements.
  • Flexible installation options
    The device is designed for both DIN rail and wall mounting, allowing for easy integration into various setups.
StarTech.com Industrial 5 Port Gigabit PoE Switch, 30W, Power Over Ethernet Switch, Hardened GbE PoE+ Unmanaged Switch, Rugged High Power Gigabit Network Switch IP-30 Housing/-40 C to 75 C - Gigabit Ethernet PoE (IESC1G50UP) - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE+) + 1 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
120 W
Jumbo Frame Support
9KB
Flow control, full duplex mode, rugged, 2KV ESD Protector, Back Pressure Support, MDI-X
IEEE 802.3, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
DC 48 - 56 V
8.15 cm x 10.4 cm x 3.2 cm
150.6 g
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
120 W
Jumbo Frame Support
9KB
Status Indicators
Power, PoE, link
4 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x 1000Base-T RJ-45 , 1 x terminal block
DC 48 - 56 V
126 Watt
Terminal block connector, mounting kit
MTBF
538451 hours
IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, FCC, RoHS, UL 60950-1, EN 60950-1, WEEE, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6
8.15 cm
10.4 cm
3.2 cm
150.6 g
Shipping Width
21.1 cm
Shipping Depth
16.2 cm
Shipping Height
6.4 cm
Shipping Weight
392.6 g
-40 °C
75 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
G3QJ StarTech.com 4-Port PoE+/PoE++ Injector 95W In Stock £275.11
Ports: 5
Managed: No
POE: PoE+
