Install a PoE-Powered, in-wall 802.11b/g/n access point with 2 RJ45 LAN / phone ports. This in-wall access point provides network and internet availability for both wired and wireless users. The sleek in-wall design with PoE enables you to use your existing CAT5 infrastructure to easily replace your standard RJ45 jacks, adding the benefits of dual LAN ports and Wireless-N connectivity.
This access point can be discretely integrated into any room where internet or network access is required. The wireless AP installs into any standard 1-gang receptacle box and features an elegant design for a seamless integration into any modern space. The sleek design ensures a tidy professional installation that is perfect for hotel rooms, hospitals, offices and schools.
The wireless access point is powered using Power over Ethernet to conveniently connect both data and power using an 802.3af PoE switch or injector, avoiding the hassle of in-wall power or external power adapters. The access point offers two front RJ45 Ethernet ports, with the first operating over the PoE connection and the second offering a transparent pass-through port that can be used for either a phone connection or a secondary LAN drop. The easy-to-incorporate nature of this AP is ideal for system integrators when planning the construction phase of schools, offices or residential buildings.
For fast performance the wireless AP is compatible with 802.11b/g/n standard supporting wireless data rates up to 300 Mbps on the 2.4GHz frequency. For a secure connection the access point supports WEP, WPA, and WPA2 authentication. The device also incorporates an easy-to-use web-based utility to provide several customization options such as multiple SSIDs, remote firmware upgrades and event reporting.
- StarTech.com In-Wall 300 Mbps 2T2R Wireless-N Access Point - radio access point - Wi-Fi
- Radio access point
- Form Factor
- In-wall mountable
- Processor
- MediaTek MT7620n
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 3.9 cm x 7.2 cm x 5.5 cm
- 84 g
- 2-year warranty
- 3.9 cm
- 7.2 cm
- 5.5 cm
- 84 g
- Enclosure Colour
- White
Processor / Memory / Storage
- Processors Installed
- MediaTek MT7620n
- Form Factor
- In-wall mountable
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
- Frequency Band
- 2.4 GHz
- Status Indicators
- Power, system, wireless
- Full duplex capability, power over Ethernet (PoE), 2T2R MIMO technology, Direct Sequence Spread Spectrum (DSSS)
- Encryption Algorithm
- AES, TKIP, WPA, WEP
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n
Aerial
- Antenna
- Internal
- FCC, RoHS
- PoE
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 20 - 90% (non-condensing)
