StarTech.com IDE to SATA Adapter Converter
Quicklinx: 5D3PWS00 Mfr#: PATA2SATA2
Connect 2 SATA hard drives to an IDE motherboard or card. This IDE to SATA Drive Adapter Kit offers a simple way to install Serial ATA hard drives using an available IDE port - a cost-effective solution for using newer SATA drives on a legacy computer or a computer with all SATA connections already in use.
This dual channel bridge lets you connect two high-speed SATA drives without the cost and effort of upgrading your IDE (Parallel ATA) motherboard, while minimizing the space required for IDE cable connections - helping to improve airflow within the case which in turn helps to optimize system performance.
Plus, the IDE to SATA Drive Motherboard Adapter includes a power connector and SATA data cables, to ensure the upgrade to SATA is easy!
To connect to a power source, SATA hard drives require SATA power. If your computer's power supply does not have a SATA power connection, the SATAPOWADAP 6in LP4 Male to Serial ATA Power Adapter will be required.
StarTech.com IDE to SATA Adapter Converter - storage controller - SATA 1.5Gb/s - Ultra ATA/133
Storage controller
Bus Type
Ultra ATA/133
SATA 1.5Gb/s
Data Transfer Rate
1.5 Gbit/s
Supported Devices
Hard drive, CD drive, DVD drive
Channel Qty
2
Max Storage Devices Qty
2
4.6 cm x 5.4 cm x 1.1 cm
13 g
Storage controller
Host Bus
Ultra ATA/133
Storage Controller
SATA 1.5Gb/s
Data Transfer Rate
1.5 Gbit/s
Supported Devices
Channel Qty
2
2
2 x SATA 1.5Gb/s - SATA
1 storage - ATA-133 - 40 PIN IDC
2 x Serial ATA cable
FCC, RoHS
Limited warranty - lifetime
4.6 cm
5.4 cm
1.1 cm
13 g
5D3P StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £2.95
5D3P StarTech.com 24" Serial ATA Cable In Stock £3.55
5D3P StarTech.com 18" Serial ATA Cable w/R Angle In Stock £3.52
5D3P StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £4.96
5D3P StarTech.com 18in SATA Serial ATA Cable In Stock £3.35
5D3P StarTech.com 36in SATA Serial ATA Cable In Stock £3.15
5D3P StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £3.55
5D3P StarTech.com 36in SATA to Right Angle SATA Serial ATA Cable In Stock £3.88
