Connect 2 SATA hard drives to an IDE motherboard or card. This IDE to SATA Drive Adapter Kit offers a simple way to install Serial ATA hard drives using an available IDE port - a cost-effective solution for using newer SATA drives on a legacy computer or a computer with all SATA connections already in use.
This dual channel bridge lets you connect two high-speed SATA drives without the cost and effort of upgrading your IDE (Parallel ATA) motherboard, while minimizing the space required for IDE cable connections - helping to improve airflow within the case which in turn helps to optimize system performance.
Plus, the IDE to SATA Drive Motherboard Adapter includes a power connector and SATA data cables, to ensure the upgrade to SATA is easy!
To connect to a power source, SATA hard drives require SATA power. If your computer's power supply does not have a SATA power connection, the SATAPOWADAP 6in LP4 Male to Serial ATA Power Adapter will be required.
- StarTech.com IDE to SATA Adapter Converter - storage controller - SATA 1.5Gb/s - Ultra ATA/133
- Storage controller
- Bus Type
- Ultra ATA/133
- Interface
- SATA 1.5Gb/s
- Data Transfer Rate
- 1.5 Gbit/s
- Supported Devices
- Hard drive, CD drive, DVD drive
- Channel Qty
- 2
- Max Storage Devices Qty
- 2
- 4.6 cm x 5.4 cm x 1.1 cm
- 13 g
- Limited lifetime warranty
- Host Bus
- Ultra ATA/133
Storage Controller
- Interface
- SATA 1.5Gb/s
- 1.5 Gbit/s
- Supported Devices
- Channel Qty
- 2
- 2
- 2 x SATA 1.5Gb/s - SATA
- Connections
- 1 storage - ATA-133 - 40 PIN IDC
- Cables Included
- 2 x Serial ATA cable
- FCC, RoHS
- Limited warranty - lifetime
- 4.6 cm
- 5.4 cm
- 1.1 cm
- 13 g
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.44 |
StarTech.com 24" Serial ATA Cable | In Stock | £5.18 |
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 18in SATA Serial ATA Data and Power Combo Cable | In Stock | £6.44 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.34 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.58 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.40 |
