The JG325B-ST is an HP JG325Bcompatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-SR4 compliant networks, with a maximum distance of up to 150 m (492 ft).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com HPE JG325B Compatible QSFP+ Module, 40GBASE-SR4, 40GbE Multi Mode Fiber Optic Transceiver, 40GE Gigabit Ethernet QSFP+, MPO Connector, 150m, 850nm, DDM, HPE 4200, FlexFabric - Lifetime Warranty (JG325B-ST) - QSFP+ transceiver module - 40GbE
- QSFP+ transceiver module - MPO multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 40GBASE-SR4
- Data Transfer Rate
- 40 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 40GbE
- Max Transfer Distance
- 150 m
- OEM Manufacturer Equivalent Part Number
- HP JG325B
- 12.2 cm x 1.86 cm x 0.85 cm
- 37.5 g
- Limited lifetime warranty
- Designed For
- HPE Apollo 4200 Qumulo Archive Node, 4200 Qumulo Hybrid Node, 4200 Qumulo Node; FlexFabric 12900E, 12900E 36-Port 100GbE QSFP28 Type X Module, 12900E 36-Port 40GbE QSFP+ Type X Module, 12902E Switch Chassis
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 40GBASE-SR4
- 40GbE
- 40 Gbps
- 850 nm
- 150 m
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
- MTBF
- 95,832,027 hours
- MSA
- HP JG325B
- 12.2 cm
- 1.86 cm
- 0.85 cm
- 37.5 g
- Shipping Width
- 12 cm
- Shipping Depth
- 20.5 cm
- Shipping Height
- 3.5 cm
- Shipping Weight
- 60 g
- Limited warranty - lifetime
- Designed For
- HPE Apollo 4200 Qumulo Archive Node, 4200 Qumulo Hybrid Node, 4200 Qumulo Node , HPE FlexFabric 12900E, 12900E 36-Port 100GbE QSFP28 Type X Module, 12900E 36-Port 40GbE QSFP+ Type X Module, 12902E Switch Chassis
