The JG234A-ST is a HP JG324A compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 10Base-ER compliant networks, with a maximum distance of up to 40 km (24.8 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com HPE JG234A Compatible SFP+ Module - 10GBASE-ER - 10GE Gigabit Ethernet SFP+ Single Mode Fiber (SMF) - 40 km DDM - Lifetime Warranty (JG234A-ST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-ER
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1550 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 40 km
- OEM Manufacturer Equivalent Part Number
- HP JG234A
- 5.84 cm x 1.39 cm x 1.37 cm
- 24 g
- Limited lifetime warranty
- Designed For
- HP A10504, A10508, A10508-V, A5800-24G-PoE, A5800-24G-SFP, A5800-48G-PoE; HPE 12504, 5120-48G-PoE+, 5500-24G-PoE+-4SFP, 5800-48G, 5900AF-48G-4XG-2QSFP+, 5900AF-48XG-4QSFP+, 5900AF-48XGT-4QSFP+, 5920AF-24XG, 7502, 7503-S, 7506-V, A5800-24G, A5800-48G; FlexFabric 1.92, 11908-V, 12902E
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-ER
- 10GbE
- 10 Gbps
- 1550 nm
- 40 km
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-ER - LC single-mode female x 2
- MTBF
- 426,514,897 hours
- FCC, MSA
- HP JG234A
- 1.6 Watt
- 5.84 cm
- 1.39 cm
- 1.37 cm
- 24 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
- Designed For
- HP A10504, A10508, A10508-V, A5800-24G-PoE Switch, A5800-24G-SFP Switch, A5800-24G-SFP Switch with 1 Interface Slot, A5800-48G-PoE Switch , HPE 12504 AC Switch Chassis, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-PoE+-4SFP HI Switch with 2 Interface Slots, 5800-48G Switch, 5900AF-48G-4XG-2QSFP+ Switch, 5900AF-48XG-4QSFP+ Switch, 5900AF-48XGT-4QSFP+ Switch, 5920AF-24XG Switch, 7502, 7503-S Switch with 1 Fabric Slot, 7506-V, A5800-24G Switch, A5800-48G , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis, 12902E Switch Chassis
