The J9152D-ST is a HP J9152D compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LRM compliant networks, with a maximum distance of up to 200 m (656 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com HPE J9152D Compatible SFP+ Module, 10GBASE-LRM, 10GbE Multi Mode (MMF) Fiber Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 200m, 1310nm, DDM, HPE 1850, 2540, 2930M, - Lifetime Warranty (J9152D-ST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LRM
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 200 m
- OEM Manufacturer Equivalent Part Number
- HP J9152D
- 5.84 cm x 1.39 cm x 1.37 cm
- 21 g
- Limited lifetime warranty
- Designed For
- HPE 20, 6120, 8-port 10, Gig-T PoE+/2-port 10; HPE Aruba 2530-24, 2530-48, 2920-24, 2920-48, 2920-48G-PoE+ 740, 2930M 24, 3800-24, 3800-48, 3810M 16, 3810M 24, 3810M 40, 3810M 48, 6200M 24, MACsec Advanced Module
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LRM
- 10GbE
- 10 Gbps
- 1310 nm
- 200 m
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-LRM - LC multi-mode female x 2
- MTBF
- 145,858,878 hours
- MSA
- HP J9152D
- 1 Watt
- 5.84 cm
- 1.39 cm
- 1.37 cm
- 21 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
- Designed For
- HPE 20-port Gig-T / 2-port 10-GbE SFP+ v2 zl Module, 6120XG Blade Switch, 8-port 10GbE SFP+ v2 zl Module, Gig-T PoE+/2-port 10-GbE SFP+ v2 zl , HPE Aruba 2530-24G-2SFP+, 2530-24G-PoE+, 2530-24G-PoE+-2SFP+, 2530-48G-2SFP+, 2530-48G-PoE+-2SFP+, 2920-24G, 2920-24G-PoE+, 2920-48G, 2920-48G-PoE+, 2920-48G-PoE+ 740 W, 2930M 24 Smart Rate POE+ 1-Slot, 3800-24G-2SFP+, 3800-24G-2SFP+ w/o EEE, 3800-24G-PoE+-2SFP+, 3800-24G-PoE+-2SFP+ w/o EEE, 3800-24SFP-2SFP+, 3800-48G-4SFP+, 3800-48G-4SFP+ w/o EEE, 3800-48G-PoE+-4SFP+, 3800-48G-PoE+-4SFP+ w/o EEE, 3810M 16SFP+ 2-slot Switch, 3810M 24G 1-slot Switch, 3810M 24G PoE+ 1-slot Switch, 3810M 40G 8 HPE Smart Rate PoE+ 1-slot Switch, 3810M 48G 1-slot Switch, 3810M 48G PoE+ 1-slot Switch, 6200M 24G Class4 PoE 4SFP+, MACsec Advanced Module
