StarTech.com HP J9151D Compatible SFP+ SM Module - 10GBase-LR
Quicklinx: FHJCWS00 Mfr#: J9151D-ST
The J9151D-ST is a HP J9151D compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com HPE J9151D Compatible SFP+ Module, 10GBASE-LR, 10GbE Single Mode (SMF) Fiber Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 10km, 1310nm, DDM, HPE 2540, 2920, 2930M - Lifetime Warranty (J9151D-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10GbE
Max Transfer Distance
10 km
HP J9151D
5.84 cm x 1.39 cm x 1.37 cm
21 g
HPE 20, 6120, 8-port 10, Gig-T PoE+/2-port 10; HPE Aruba 2540 24, 2540 48, 2920-24, 2920-48, 2920-48G-PoE+ 740, 2930F 24, 2930F 48, 2930F 8G, 2930M 24, 2930M 40, 2930M 48, 3800-24, 3800-48, 3810M 16, 3810M 24, 3810M 40, 3810M 48, 8320, 8325-48, MACsec Advanced Module
Plug-in module
Wired
Cabling Type
10GBase-LR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-LR - LC single-mode female x 2
MTBF
1,386,624,697 hours
MSA
HP J9151D
1.3 Watt
5.84 cm
1.39 cm
1.37 cm
21 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
HPE 20-port Gig-T / 2-port 10-GbE SFP+ v2 zl Module, 6120XG Blade Switch, 8-port 10GbE SFP+ v2 zl Module, Gig-T PoE+/2-port 10-GbE SFP+ v2 zl , HPE Aruba 2540 24G 4SFP+, 2540 24G PoE+ 4SFP+, 2540 48G 4SFP+, 2540 48G PoE+ 4SFP+, 2920-24G, 2920-24G-PoE+, 2920-48G, 2920-48G-PoE+, 2920-48G-PoE+ 740 W, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP+, 2930F 24G PoE+ 4SFP+ TAA, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 2930F 48G PoE+ 4SFP+ TAA, 2930F 8G PoE+ 2SFP+, 2930M 24 Smart Rate POE+ 1-Slot, 2930M 24G 1-Slot, 2930M 24G POE+ 1-Slot, 2930M 40G 8 HPE Smart Rate PoE+ 1-slot Switch, 2930M 48G 1-Slot, 2930M 48G POE+ 1-Slot, 3800-24G-2SFP+, 3800-24G-2SFP+ w/o EEE, 3800-24G-PoE+-2SFP+, 3800-24G-PoE+-2SFP+ w/o EEE, 3800-24SFP-2SFP+, 3800-48G-4SFP+, 3800-48G-4SFP+ w/o EEE, 3800-48G-PoE+-4SFP+, 3800-48G-PoE+-4SFP+ w/o EEE, 3810M 16SFP+ 2-slot Switch, 3810M 24G 1-slot Switch, 3810M 24G PoE+ 1-slot Switch, 3810M 40G 8 HPE Smart Rate PoE+ 1-slot Switch, 3810M 48G 1-slot Switch, 3810M 48G PoE+ 1-slot Switch, 8320, 8325-48Y8C, MACsec Advanced Module
