StarTech.com HP AJ716B 8 Gb Short Wave SFP+
Quicklinx: CRFYWS00 Mfr#: AJ716BST
Type: Modules
Hurry, only 3 left in stock!
£57.74 ex VAT
£69.28 inc VAT
Add reliable and cost-effective 8 Gigabit Fiber Channel Short Wave connections over multimode fiber with this SFP+ module. This HP compatible 8 Gigabit Fibre Channel Short Wave SFP+ is engineered by StarTech.com to deliver what you want most in your network connections: reliable performance. Built to exacting specifications and fully tested to ensure maximum performance, you can install this high-quality fiber transceiver module into HP networking devices that support the HP AJ716B FC SFP+ transceiver module, as well as other major brands of networking equipment.
This 8Gb Short Wave B-series FC SFP+ provides Fibre Channel Short Wave throughput (2GFC, 4GFC and 8GFC) up to 300 m (984 ft.) over multimode fiber at a wavelength of 850nm using an LC connector. It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 8G FC SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The 8 Gigabit multimode SFP+ is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP AJ716B optical transceiver. The StarTech.com FC SFP+ transceiver module is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP+ products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this FC SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a range of 8 Gigabit Fibre Channel networking devices.
  • StarTech.com SFPs
    All StarTech.com SFP & SFP+ transceiver modules are backed by a lifetime warranty and free lifetime multilingual technical support. StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com HPE AJ716B Compatible SFP+ Module, 8G Fiber Channel SW, 8GbE Multi Mode (MMF) Fiber Optic Transceiver, LC Connector, 300m, 850nm, DDM, HPE SN4000, SN6500, SN8600B, Mini GBIC - Lifetime Warranty (AJ716BST) - SFP+ transceiver module - 4Gb Fibre Channel (SW), 2Gb Fibre Channel (SW), 8Gb Fibre Channel (SW)
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
Fibre Channel
Data Transfer Rate
8 Gbps
Optical Wave Length
850 nm
Max Transfer Distance
300 m
HP AJ716B
1.39 cm x 5.84 cm x 1.26 cm
30 g
Plug-in module
Silver
Wired
Cabling Type
Fibre Channel
Data Transfer Rate
8 Gbps
Optical Wave Length
850 nm
300 m
Full duplex mode
1 x 8Gb Fibre Channel (SW) - LC multi-mode female x 2
UL, FCC, RoHS, MSA
HP AJ716B
1.39 cm
5.84 cm
1.26 cm
30 g
70 °C
5 - 95%
Type: Modules
