StarTech.com HP 455889-B21 Compatible SFP+ MM Module - 10GBase-LRM
Quicklinx: FHH2WS00 Mfr#: 455889-B21-ST
£111.08 ex VAT
£133.29 inc VAT
The 455889-B21-ST is a HP 455889-B21 compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LRM compliant networks, with a maximum distance of up to 200 m (656 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com HPE 455889-B21 Compatible SFP+ Module, 10GBASE-LRM, 10GbE Multi Mode Fiber Optic Transceiver (MMF), 10GE Gigabit Ethernet SFP+, LC 200m, 1310nm, DDM, HPE BladeSystem, c-Class - Lifetime Warranty (455889-B21-ST) - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-LRM
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
200 m
HP 455889-B21
5.84 cm x 1.39 cm x 1.37 cm
21 g
HP 10Gb Ethernet Pass-Thru Module for c-Class BladeSystem, NC522SFP, NC524SFP; HPE 6120XG Blade Switch; Virtual Connect Flex-10
Plug-in module
Wired
Cabling Type
10GBase-LRM
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
200 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-LRM - LC multi-mode female x 2
MTBF
145,858,878 hours
MSA
HP 455889-B21
1 Watt
5.84 cm
1.39 cm
1.37 cm
21 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
HP 10Gb Ethernet Pass-Thru Module for c-Class BladeSystem, NC522SFP, NC524SFP , HPE 6120XG Blade Switch , HPE Virtual Connect Flex-10
