The 455886-B21-ST is a HP 455886-B21 compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com HPE 455886-B21 Compatible SFP+ Module, 10GBASE-LR, 10GbE Single Mode (SMF) Fiber Optic Transceiver, LC 10km, 1310nm DDM, HPE BladeSystem 562SFP+ 560SFP+, Mini GBIC Transceiver - Lifetime Warranty (455886-B21-ST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- HP 455886-B21
- 5.84 cm x 1.39 cm x 1.37 cm
- 21 g
- Limited lifetime warranty
- Designed For
- HPE SimpliVity 380 Gen10 Node, 380 Gen9 Node; Virtual Connect Flex-10
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LR
- 10GbE
- 10 Gbps
- 1310 nm
- 10 km
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-LR - LC single-mode female x 2
- MTBF
- 1,386,624,697 hours
- MSA
- HP 455886-B21
- 1.3 Watt
- 5.84 cm
- 1.39 cm
- 1.37 cm
- 21 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
- Designed For
- HPE SimpliVity 380 Gen10 Node, 380 Gen9 Node , HPE Virtual Connect Flex-10
