StarTech.com Hot Swap SATA/SAS Backplane RAID Bays – 3 Hard Drive Mobile Rack
Quicklinx: 6PDDWS00 Mfr#: SATSASBAY3BK
Hot Swap up to three 3.5in SAS or SATA hard drives in and out of this removable backplane; features 3-in-2 design, that requires only two 5.25in drive bays. The SATSASBAY3BK SAS/SATA Backplane offers an easy-to-use and cost-effective SATA hot swap solution and features a sturdy and compact 3-in-2 design that lets you install up to three 2.5"/3.5" SATA or SAS hard drives into only two 5.25in bays.
With support for SATA/SAS HDD the mobile rack/backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
StarTech.com Hot Swap SATA/SAS Backplane RAID Bays 3 Hard Drive Mobile Rack - storage mobile rack
Storage mobile rack
Expansion Bays
3 x hot-swap - 3.5"
Compatible Bay
2 5.25" x 1/2H
Hard Drive Form Factor Compatibility
3.5"
Supported Interface
SATA-300 / SAS
Drive Connector
22 pin Serial ATA
Data indicator, power indicator, cooling fan
Product Material
Plastic, aluminium, steel
14.6 cm x 20.2 cm x 8.6 cm
1.2 kg
1-year warranty
Storage mobile rack
3.5"
Product Material
Supported Interface
SATA-300 / SAS
Bays
3 x hot-swap - 3.5"
3 x SATA 3Gb/s / SAS - SATA combo
1 storage - Serial ATA-300 - 7 pin Serial ATA , 2 storage - Serial ATA-300 - 22 pin Serial ATA
Compatible Bay
2 x external 5.25" x 1/2H
FCC, RoHS
Limited warranty - 1 year
14.6 cm
20.2 cm
8.6 cm
1.2 kg
50 °C
6PDD StarTech.com 24" Serial ATA Cable In Stock £3.55
6PDD StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £4.96
6PDD StarTech.com 36in SATA Serial ATA Cable In Stock £3.15
6PDD StarTech.com 24in Latching SATA Cable In Stock £4.66
6PDD StarTech.com SATA to LP4 Power Cable Adapter In Stock £4.35
6PDD StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £14.58
6PDD StarTech.com 4 Drive 3.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £76.63
6PDD StarTech.com 6in LP4 to LP4 SATA Power Y Cable Adapter In Stock £3.30
