Hot Swap up to three 3.5in SAS or SATA hard drives in and out of this removable backplane; features 3-in-2 design, that requires only two 5.25in drive bays. The SATSASBAY3BK SAS/SATA Backplane offers an easy-to-use and cost-effective SATA hot swap solution and features a sturdy and compact 3-in-2 design that lets you install up to three 2.5"/3.5" SATA or SAS hard drives into only two 5.25in bays.
With support for SATA/SAS HDD the mobile rack/backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
- StarTech.com Hot Swap SATA/SAS Backplane RAID Bays 3 Hard Drive Mobile Rack - storage mobile rack
- Storage mobile rack
- Black
- Expansion Bays
- 3 x hot-swap - 3.5"
- Compatible Bay
- 2 5.25" x 1/2H
- Hard Drive Form Factor Compatibility
- 3.5"
- Supported Interface
- SATA-300 / SAS
- Drive Connector
- 22 pin Serial ATA
- Data indicator, power indicator, cooling fan
- Product Material
- Plastic, aluminium, steel
- 14.6 cm x 20.2 cm x 8.6 cm
- 1.2 kg
- 1-year warranty
- 3.5"
- Product Material
- Black
- SATA-300 / SAS
- Bays
- 3 x SATA 3Gb/s / SAS - SATA combo
- Connections
- 1 storage - Serial ATA-300 - 7 pin Serial ATA , 2 storage - Serial ATA-300 - 22 pin Serial ATA
- Compatible Bay
- 2 x external 5.25" x 1/2H
- FCC, RoHS
- Limited warranty - 1 year
- 14.6 cm
- 20.2 cm
- 8.6 cm
- 1.2 kg
- 0 °C
- 50 °C
StarTech.com 24" Serial ATA Cable | In Stock | £5.18 |
StarTech.com 18in SATA Serial ATA Data and Power Combo Cable | In Stock | £6.44 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.58 |
StarTech.com 24in Latching SATA Cable | In Stock | £5.98 |
StarTech.com SATA to LP4 Power Cable Adapter | In Stock | £5.24 |
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £17.78 |
