StarTech.com Hot Swap Bay 2.5" SATA SSD HDD
Quicklinx: CZCHWS00 Mfr#: S251BU31REM
Type: Storage enclosure
HD Size: 2.5"
More than 50 in stock
£41.44 ex VAT
£49.72 inc VAT
This USB 3.1 (10Gbps) hard drive enclosure is a spare SATA drive enclosure for use with the StarTech.com S251BU31REM Hot-Swap Hard Drive Bay for 2.5" SATA SSD/HDD.
  • Add swappable storage capability
    This SATA to USB enclosure can be used as an extra hard drive enclosure for the hot-swap bay in order to provide multiple enclosures that can be swapped in and out of a main computer system. It's perfect for adding drives for backup rotations, and data recovery strategies.
  • Take your data with you
    If you need access to your data outside of the office, you can use the enclosure as a standard USB 3.1 (10 Gbps) enclosure - a powerful external storage solution when you need access to your files while you're on the road. The enclosure includes a Micro-USB to USB-A and a Micro-USB to USB-C cable, so you can plug the enclosure into your laptop and access your data anywhere you go.
StarTech.com Hot Swap Hard Drive Bay for 2.5" SATA SSD / HDD - Portable - USB 3.1 (10Gbps) Removable Hard Drive Enclosure (S251BU31REM) - storage enclosure - SATA 6Gb/s - SATA 6Gb/s, USB-C
Storage enclosure - external
Bus Type
SATA 6Gb/s, USB-C
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
Product Material
Durable aluminium
Power Source
USB bus
P/N: S251BU31REMD
2.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
SATA 6Gb/s, USB-C
Product Material
Durable aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
1
ASMedia ASM1351
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s (internal)
1 x USB 3.1 (Gen 2) - 24 pin USB-C , 1 x SATA 6Gb/s - 22 pin Serial ATA
Mounting hardware
1 x USB-C to micro-USB cable - external , 1 x micro-USB to USB cable - external
LED indicator, UASP transfer protocol, tested with up to 2TB 7200 RPM hard drives
MTBF
100,000 hours
FCC, RoHS
Power Source
USB bus
10 - 90%
P/N: S251BU31REMD
CZCH StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £14.75
CZCH StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £36.57
CZCH StarTech.com USB 3.1 Gen 2 Enclosure In Stock £36.28
CZCH StarTech.com Hot Swap Bay 2.5" SATA SSD HDD In Stock £41.44
HD Size: 2.5"
Price Range Ex VAT: 0 - 50
