StarTech.com Heatsink Thermal Pads 5 Pack
Quicklinx: D6R2WS00 Mfr#: HSFPHASECM
Type: Heatsink
39 in stock
£4.48 ex VAT
£5.37 inc VAT
Improves heat transfer between a CPU/chipset and heatsink with easy-to-use thermal pads. This 5 pack of Thermal Pads offers a suitable alternative to using heatsink paste/grease. The thermal pads remain solid at room temperature, and soften at heatsink operating temperatures - eliminating the mess of heat grease, while maximizing heat conduction to create a cooler operating environment for your hard working CPU.
StarTech.com Heatsink Thermal Pads - Pack of 5 - Thermal Pad - Thermal pad - gray (pack of 5 ) - HSFPHASECM thermal pad
Thermal pad
Packaged Quantity
5 (specifications are for single item)
Grey
3 cm x 3 cm
P/N: FAN1156PWM
Packaged Quantity
Thermal pad
3 cm
3 cm
Grey
P/N: FAN1156PWM
Type: Heatsink
Price Range Ex VAT: 0 - 50
