Connect HDMI devices to a VGA monitor with stereo audio separation. The HDMI2VGA HDMI to VGA converter converts digital HDMI or DVI video signals to analog VGA, taking the input resolution from your device and converting it into an analog signal at the same resolution.
The converter also separates the audio stream from the HDMI signal (HDMI LPCM-2 Channel) and converts it to analog stereo audio that can be used with the VGA display.
With support for resolutions of up to 1080p, the HDMI2VGA converter is a perfect solution for connecting video cards (desktop or laptop) or consumer electronics devices such as game consoles or home theater receivers that offer an HDMI Out port to a VGA display.
The HDMI2VGA adapter/converter is simple to use, with no complicated settings.
- StarTech.com HDMI® to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1920x1200 1080p - HDMI to VGA HD15 (HDMI2VGA) - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x component video output - RCA x 3 (on supplied cable) , 1 x audio line-out - mini-phone stereo 3.5 mm
- 7.6 cm x 7.6 cm x 9.2 cm
- Enclosure Colour
- Black
- 2-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x component video output - RCA x 3 (on supplied cable) - male , 1 x audio line-out - mini-phone stereo 3.5 mm - female
- Voltage Required
- AC 120/230 V
- Cables Included
- 1 x VGA / component video adapter
- FCC, RoHS
- 7.6 cm
- 7.6 cm
- 9.2 cm
- 172 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 60%
StarTech.com 6 ft Monitor VGA Cable - HD15 M/M | In Stock | £4.14 |
StarTech.com 6 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £3.66 |
StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M | In Stock | £3.38 |
StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F | In Stock | £3.43 |
StarTech.com 12 ft PC Speaker Extension Audio Cable | In Stock | £3.46 |
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.15 |
StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p | In Stock | £125.06 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £10.80 |
