Connect an SDI Display to your HDMI Video Source. The HD2SDI HDMI to dual SDI converter enables you to turn your HDMI audio/video signal into two 3G SDI video outputs. The 3G SDI video outputs can then be individually extended up to 755ft (230m) over standard coaxial cable for large scale HD-SDI video distribution.
With dual SDI outputs, you can connect your HDMI video source to a local SDI display and output an additional SDI signal into your broadcasting equipment, providing a scalable solution for any SDI broadcasting application that requires an HDMI input.
To ensure you maintain perfect high-definition video quality, the HD-SDI converter supports resolutions up to 1080p, which lets you convert HDMI to SDI without sacrificing video quality.
For hassle-free installation, the HDMI to SDI converter offers a plug-and-play solution that includes pre-installed mounting brackets and requires no software or driver installation.
- StarTech.com HDMI to SDI Converter - HDMI to 3G SDI Adapter with Dual SDI Output - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin HDMI Type A , 2 x 3G-SDI output - BNC
- 10 cm x 7 cm x 2.5 cm
- Enclosure Colour
- Black
- 2-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin HDMI Type A - female , 2 x 3G-SDI output - BNC - female
- Voltage Required
- AC 120/230 V
- FCC, RoHS
- 10 cm
- 7 cm
- 2.5 cm
- 202 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
StarTech.com HDMI to SDI Converter – HDMI to 3G SDI Adapter with Dual SDI Output | In Stock | £148.53 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £10.69 |
