StarTech.com HDMI to SDI Converter – HDMI to 3G SDI Adapter with Dual SDI Output
Quicklinx: 9KZCWS00 Mfr#: HD2SDI
Hurry, only 1 left in stock!
£148.53 ex VAT
£178.23 inc VAT
Connect an SDI Display to your HDMI Video Source. The HD2SDI HDMI to dual SDI converter enables you to turn your HDMI audio/video signal into two 3G SDI video outputs. The 3G SDI video outputs can then be individually extended up to 755ft (230m) over standard coaxial cable for large scale HD-SDI video distribution.
With dual SDI outputs, you can connect your HDMI video source to a local SDI display and output an additional SDI signal into your broadcasting equipment, providing a scalable solution for any SDI broadcasting application that requires an HDMI input.
To ensure you maintain perfect high-definition video quality, the HD-SDI converter supports resolutions up to 1080p, which lets you convert HDMI to SDI without sacrificing video quality.
For hassle-free installation, the HDMI to SDI converter offers a plug-and-play solution that includes pre-installed mounting brackets and requires no software or driver installation.
StarTech.com HDMI to SDI Converter - HDMI to 3G SDI Adapter with Dual SDI Output - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A , 2 x 3G-SDI output - BNC
10 cm x 7 cm x 2.5 cm
Enclosure Colour
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A - female , 2 x 3G-SDI output - BNC - female
AC 120/230 V
FCC, RoHS
10 cm
7 cm
2.5 cm
202 g
Enclosure Colour
5 - 90% (non-condensing)
9KZC StarTech.com HDMI to SDI Converter – HDMI to 3G SDI Adapter with Dual SDI Output In Stock £148.53
9KZC StarTech.com DC Power Adapter - 5V, 3A In Stock £10.69
Price Range Ex VAT: 100 - 150
