StarTech.com HDMI to DisplayPort Converter - 4K
Quicklinx: BM05WS00 Mfr#: HD2DP
48 in stock
£35.38 ex VAT
£42.45 inc VAT
Connect your HDMI enabled Ultrabook or laptop to a DP monitor using this compact, USB-powered adapter. This HDMI to DisplayPort converter lets you connect an HDMI enabled video source, such as a Blu-ray player, camera, video game console or computer, to a DisplayPort monitor or projector.
The compact adapter is USB-powered and supports video resolutions up to 4K, giving you the freedom to connect your 4K HDMI equipped Ultrabook or laptop to an Ultra HD DisplayPort projector. It's the perfect solution for a variety of settings, including office boardrooms or trade shows.
This HDMI to DisplayPort converter can save you time and money. It works seamlessly with your existing setup when connecting a new source or display, eliminating cost by ensuring that you won't need to change or upgrade your main components.
The HDMI to DP adapter offers plug-and-play installation, providing a hassle-free setup with no software or drivers to install. Plus, the adapter features a compact design that blends seamlessly with your workstation or entertainment center.
Using the HDMI to DisplayPort adapter, you can connect a secondary monitor to your laptop. Having the extra display offers a definite productivity boost because the added screen space means you can work more efficiently by multitasking more easily, and accomplish more in the same amount of time. It's perfect for office use where you'll often view documents, spreadsheets, and web pages across multiple screens.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This HDMI to DisplayPort (DP) converter lets you deliver high-resolution content to your DP enabled display, through the astonishing quality of Ultra HD. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications. Support for 4K makes the adapter great for video production applications such as viewing and editing post-production video or viewing camera footage from an HDMI source on your DisplayPort monitor.
  • Save money and hassle
    This HDMI to DisplayPort converter can save you time and money. The HDMI to DP adapter offers plug-and-play installation, providing a hassle-free setup with no software or drivers to install. Plus, the adapter features a compact design that blends seamlessly with your workstation or entertainment center.
  • Be more productive
  • Enjoy Ultra HD picture quality
StarTech.com 4K 30Hz HDMI to DisplayPort Video Adapter w/ USB Power - 6 in - HDMI 1.4 (Male) to DP 1.2 (Female) Active Monitor Converter (HD2DP) - video converter - black
Video converter
Max Resolution
4096 x 2160
1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort output - 20 pin DisplayPort , 1 x USB (power only) - 4 pin USB Type A
2.3 cm x 22 cm x 1.3 cm
Enclosure Colour
Video converter
Max Resolution
4096 x 2160
1 x HDMI input - 19 pin HDMI Type A - male , 1 x DisplayPort output - 20 pin DisplayPort - female , 1 x USB (power only) - 4 pin USB Type A - male
1 x USB extension cable
Plug and Play, FCC, RoHS, WEEE
2.3 cm
22 cm
1.3 cm
36 g
Enclosure Colour
-20 °C
85 °C
20 - 95% (non-condensing)
BM05 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £16.18
BM05 StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £11.14
BM05 StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.97
BM05 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.51
BM05 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.06
BM05 StarTech.com HDMI or DVI to DisplayPort Active Converter In Stock £67.55
BM05 StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £19.63
BM05 StarTech.com DisplayPort to HDMI - 4K In Stock £14.41
BM05 StarTech.com HDMI to DisplayPort Converter - 4K In Stock £35.38
BM05 StarTech.com HDMI to DisplayPort, VGA or DVI Adapter In Stock £59.59
Price Range Ex VAT: 0 - 50
