StarTech.com HDMI to Composite Converter with Audio
Quicklinx: 7X19WS00 Mfr#: HD2VID
  • High-Definition Multimedia Interface (HDMI)
Convert an HDMI? Signal with Supporting Audio to Work with Legacy Composite Video Televisions and Displays. The HD2VID HDMI? to Composite Video Converter (with Audio) converts a digital HDMI video source (with supporting audio) to work with analog Composite video televisions and displays in both NTSC and PAL systems. The HDMI to Composite converter provides features that ensure the highest quality output image, such as noise reduction, frame rate conversion and adaptive contrast enhancement, while an easy to use On-Screen Display (OSD) allows you to monitor your display status. Support for a wide range of HDTV and PC input resolutions make this versatile HDMI converter a perfect solution for using newer devices with existing legacy displays.
StarTech.com HDMI to Composite Converter with Audio - video converter - white
Video converter
Max Resolution
1280 x 800
1 x HDMI input - 19 pin HDMI Type A , 1 x composite video output - RCA , 1 x audio line-out - RCA x 2
11.4 cm x 6.5 cm x 2.6 cm
Enclosure Colour
White
Video converter
Max Resolution
1280 x 800 at 60 Hz
1 x HDMI input - 19 pin HDMI Type A - female , 1 x composite video output - RCA - female , 1 x audio line-out - RCA x 2 - female
DC 5 V (60 Hz)
3 Watt
1 x power adapter
11.4 cm
6.5 cm
2.6 cm
120 g
Enclosure Colour
White
20 - 90%
7X19 StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV In Stock £70.89
7X19 StarTech.com 6 ft 180° Rotating High Speed HDMI Cable - HDMI - M/M In Stock £7.34
7X19 StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p In Stock £123.72
7X19 StarTech.com DC Power Adapter - 5V, 3A In Stock £10.69
