StarTech.com HDMI Signal Booster 115ft
Quicklinx: C64ZWS00 Mfr#: HDBOOST
£22.35 ex VAT
£26.82 inc VAT
Amplify the strength of your HDMI signal to extend your video source up to 115 ft. over standard HDMI cable. This HDMI signal booster lets you increase the signal strength of your HDMI video source so you can connect an HDMI display up to 115 feet away (35m) using standard HDMI cables. You can place the booster inline between two HDMI cables, up to 82 ft. in length at the video input, and up to 33 ft. in length at the video output.
With its small form factor, the HDMI booster is easy to hide or a non-intrusive installation. You don't need an external power adapter to operate the signal booster, and it includes mounting hardware, so installing it is hassle-free. By extending your video signal using standard HDMI cables, the HDMI booster is a cost-effective alternative to more expensive HDMI extension systems that require the the installation of CAT5 or CAT6 cabling infrastructure.
The HDMI booster features an equalization switch with 10 different levels, that lets you adjust the amplification of your HDMI signal based on the distance of your cables, so that you can ensure your HDMI signal will be perfect, even at distances up to 115 ft. (35 m). Perfect for boardrooms, offices or classrooms that may have varying distances depending on the room size.
When extending HDMI long distances over standard video cabling, higher resolutions can become unavailable. Using the HDMI signal booster ensures that you'll still be able to depend on high-definition resolutions up to 1080p at 60Hz.
StarTech.com 115 ft/35 m HDMI Signal Booster - 1080p Signal Repeater - HDMI Inline Amplifier & Extender - 7.1 Audio Support (HDBOOST) - video/audio extender
Video/audio extender
External
Max Transfer Distance
35 m
External
Wired
35 m
Status Indicators
7.1 channel audio support
2 x HDMI - 19 pin HDMI Type A female
2 mounting brackets, 4 x screws
Mounting Kit
Included
FCC, RoHS, WEEE, RCM
70 °C
5 - 90%
C64Z StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.28
C64Z StarTech.com 1m USB to Type N Barrel 5V DC Power Cable - USB A to 5.5mm DC In Stock £4.90
C64Z StarTech.com HDMI Signal Booster 115ft In Stock £22.35
C64Z StarTech.com HDMI Signal Booster - 4K 60Hz In Stock £68.94
C64Z StarTech.com 8K 60Hz HDMI Signal Booster In Stock £95.46
