StarTech.com HDMI over Single Cat 5e/6 Extender with Power over Cable Ethernet and IR - 330 ft
Quicklinx: 90WSWS00 Mfr#: ST121HDT4P
The ST121HDT4P HDMI over CAT5e/6 video extender kit lets you extend HDMI video and audio by up to 330 feet (100 meters) over a single Cat5e/6 cable. For added versatility both the extender and receiver can be powered by the same single power source using Power Over Cable (POC).
This versatile HDMI extender also allows you to extend infrared for an IR remote control, and 2 Ethernet LAN connections over the same Cat5e/6 cable.
With support for high-definition resolutions of up to 4K and 1080p plus the accompanying digital audio, this cost-effective HD extender is a Plug-and-Play solution that can easily be installed using Ethernet infrastructure wiring.
The HDMI over Cat6 video extender kit includes both the local transmitter and remote receiver units, perfect for point-to-point digital signage applications that require high quality HDMI video.
For additional distance, HDMI cables up to 32-feet (10-meters) in length can be used on the local and remote end.
StarTech.com HDMI over Single Cat 5e/6 Extender with Power over Cable Ethernet and IR - 330 ft - video/audio/infrared extender
Video/audio/infrared extender
External
North America, United Kingdom, Europe
Transmission Medium
CAT 5e/6
Max Transfer Distance
100 m
AC 120/230 V
External
Wired
Max Resolution
1920 x 1080 / 1080p
100 m
1 x video - HDMI - 19 pin HDMI Type A , 1 x IrDA
FCC, RoHS
External power adapter
Installed Qty
2
AC 120/230 V
90WS StarTech.com 75 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £29.25
90WS StarTech.com 75ft Orange Cat6 Patch Cable In Stock £29.25
