The ST121HDT4P HDMI over CAT5e/6 video extender kit lets you extend HDMI video and audio by up to 330 feet (100 meters) over a single Cat5e/6 cable. For added versatility both the extender and receiver can be powered by the same single power source using Power Over Cable (POC).
This versatile HDMI extender also allows you to extend infrared for an IR remote control, and 2 Ethernet LAN connections over the same Cat5e/6 cable.
With support for high-definition resolutions of up to 4K and 1080p plus the accompanying digital audio, this cost-effective HD extender is a Plug-and-Play solution that can easily be installed using Ethernet infrastructure wiring.
The HDMI over Cat6 video extender kit includes both the local transmitter and remote receiver units, perfect for point-to-point digital signage applications that require high quality HDMI video.
For additional distance, HDMI cables up to 32-feet (10-meters) in length can be used on the local and remote end.
- StarTech.com HDMI over Single Cat 5e/6 Extender with Power over Cable Ethernet and IR - 330 ft - video/audio/infrared extender
- Video/audio/infrared extender
- Form Factor
- External
- Localisation
- North America, United Kingdom, Europe
- Transmission Medium
- CAT 5e/6
- Max Transfer Distance
- 100 m
- Power
- AC 120/230 V
- 2-year warranty
- Form Factor
- External
- Localisation
- Connectivity Technology
- Wired
- Max Resolution
- 1920 x 1080 / 1080p
- 100 m
- 1 x video - HDMI - 19 pin HDMI Type A , 1 x IrDA
- FCC, RoHS
- Power Device
- External power adapter
- Installed Qty
- 2
- Voltage Required
- AC 120/230 V
- Limited warranty - 2 years
