StarTech.com HDMI Over IP Video Extender
Quicklinx: CFQNWS00 Mfr#: IPUSB2HD3
Select:
  • HDMI
This HDMI over IP extender lets you share an HDMI display or projector with the wireless or wired computer on your network. With intuitive controls and effortless screen sharing, this extender makes it easier than ever for users to collaborate and deliver presentations in boardrooms and office meetings.
The IP video extender supports resolutions up to 1080p and features two built-in USB ports, enabling you to connect remote USB devices to your computer from your display. It's the perfect solution for controlling a computer from wherever the adapter is located.
The IP video extender helps you boost your office productivity, by making it easier for users to collaborate and communicate. The included software lets you connect multiple computers and easily switch between which user is sharing their content with the HDMI display, unlike some wireless video systems that are difficult to configure and require users to disconnect and reconnect manually. You can even use the video-over-IP extender to share information with a remote audience, such as connecting to a remote display over an office LAN, to hold remote meetings while you're in another part of the office.
With this IP video extender, you can turn your HDMI television, monitor or projector into an IP display that can connect to any Windows computer on your network, making it perfect for conference rooms and classrooms where different ideas are shared by users who bring their own computers.
With a built-in USB hub, you can use your computer to access two remote USB devices at your remote display, enabling you or your customers to control the computer from the remote location. Remote operation can be used to create interactive digital signage, to engage your customers. Or, if you're using the video-over-IP extender as part of your IT infrastructure, you can use the USB extender to add a remote KVM console that you can use to control your server from a remote location.
StarTech.com HDMI Over IP Extender with 2-port USB Hub - 1080p - video/audio extender - HDMI
Video/audio extender
External
HDMI
Max Transfer Distance
100 m
AC 120/230 V
External
Wired
HDMI
Max Resolution
1920 x 1200 / 1080p
100 m
Built-in 2-port USB 2.0 hub
1 x HDMI - 19 pin HDMI Type A female , 2 x USB 2.0 - Type A female
Foot pad set
1 x USB cable , 1 x network cable
Mounting Kit
Included
FCC, RoHS
External power adapter
AC 120/230 V
