Connect to, and share an HDMI display or projector over an IP network.
The IPUSB2HD2 HDMI over IP Extender delivers a versatile HDMI-IP link between PCs on your network and an HDMI monitor/projector, at full high definition (1080p, 1920x1080) video resolution. Accompanying audio signals are transmitted directly through the HDMI output, or separately through the built-on 3.5mm stereo output port. An ideal solution for sharing a display or projector over an Ethernet network so that even PCs lacking digital video output can still connect, the IP/HDMI adapter can communicate through a network router at transmission distances up to 100m (300ft). Plus, it offers 2 USB 2.0 ports on the display side, to connect and share peripherals such as USB storage or keyboard/mouse input with the connected PC. Alternatively, the device can be used directly connected as a USB to HDMI adapter.
- StarTech.com HDMI over IP Extender with Audio - video/audio extender - 1GbE, HDMI
- Video/audio extender
- Form Factor
- External
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- 1GbE, HDMI
- Max Transfer Distance
- 100 m
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows Vista / XP / 7
- 7.1 cm x 13.3 cm x 2.7 cm
- 142 g
- 2-year warranty
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- 1GbE, HDMI
- 1 Gbps
- Max Resolution
- 1920 x 1080 / 1080p
- 100 m
- 1 x - input - RJ-45 female , 1 x display / video - HDMI output - 19 pin HDMI Type A female , 2 x USB 2.0 - Type A female , 1 x mini-USB - Type B female , 1 x microphone (input) - mini jack , 1 x audio (output) - mini jack
- WHQL, FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- OS Required
- 7.1 cm
- 13.3 cm
- 2.7 cm
- 142 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 10 - 80%
