StarTech.com HDMI Over Fiber Extender with IR Control – SC Fiber - 2600ft (800m) - 1920x1200/1080p
Quicklinx: 8SF9WS00 Mfr#: ST121HDFXA
Extend HDMI video and audio over SC Multi Mode fiber, with Infrared control. The ST121HDFXA is a long-range HDMI video extender kit that uses SC fiber optic cable to extend video/audio from an HDMI-equipped device to a remote display up to 2600 feet (800 Meters) away. The extender supports full High-Definition video (1920x1200 / 1080p) and includes both the transmitter and receiver, for a complete ready-to-use digital signage solution.
Not only is this an incredibly long range solution that can extend an HDMI signal across or between buildings, but because fiber optics transmit data using light rather than copper, it will not cause or be effected by electromagnetic Interference (EMI).
For convenient, time-saving control of the media source, the HDMI extender also offers Infrared (IR) extension, which enables you to control the HDMI audio-video source from either end of the connection. The kit also includes optional mounting hardware for a clean and professional installation.
StarTech.com HDMI® Over Fiber Extender with IR Control - HDMI to SC Fiber Converter Extender up to 2600ft (800m) - 1920x1200 / 1080p (ST121HDFXA) - video/audio extender - Fibre Channel, HDMI
Video/audio extender
External
Data Transfer Rate
3.4 Gbps
Fibre Channel, HDMI
Transmission Medium
Fibre optic
Max Transfer Distance
800 m
AC 120/230 V
9.7 cm x 12.9 cm x 2.6 cm
445 g
External
Wired
Fibre Channel, HDMI
Data Transfer Rate
3.4 Gbps
Max Resolution
1080p @ 60 Hz
800 m
1 x HDMI , 1 x - Fibre Channel - SC multi-mode female , 1 x IrDA
FCC, RoHS
External power adapter
Installed Qty
2
AC 120/230 V
9.7 cm
12.9 cm
2.6 cm
445 g
0 - 80%
8SF9 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
8SF9 StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £215.74
8SF9 StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £96.64
8SF9 StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) In Stock £359.75
8SF9 StarTech.com HDMI over CAT6 with USB - 50m In Stock £183.30
8SF9 StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
8SF9 StarTech.com 4K 60Hz HDBaseT extender - 70m (100m @ 1080) In Stock £435.65
8SF9 StarTech.com HDMI over CAT6 Extender In Stock £105.96
