Extend HDMI video and audio over SC Multi Mode fiber, with Infrared control. The ST121HDFXA is a long-range HDMI video extender kit that uses SC fiber optic cable to extend video/audio from an HDMI-equipped device to a remote display up to 2600 feet (800 Meters) away. The extender supports full High-Definition video (1920x1200 / 1080p) and includes both the transmitter and receiver, for a complete ready-to-use digital signage solution.
Not only is this an incredibly long range solution that can extend an HDMI signal across or between buildings, but because fiber optics transmit data using light rather than copper, it will not cause or be effected by electromagnetic Interference (EMI).
For convenient, time-saving control of the media source, the HDMI extender also offers Infrared (IR) extension, which enables you to control the HDMI audio-video source from either end of the connection. The kit also includes optional mounting hardware for a clean and professional installation.
- StarTech.com HDMI® Over Fiber Extender with IR Control - HDMI to SC Fiber Converter Extender up to 2600ft (800m) - 1920x1200 / 1080p (ST121HDFXA) - video/audio extender - Fibre Channel, HDMI
- Video/audio extender
- Form Factor
- External
- Data Transfer Rate
- 3.4 Gbps
- Data Link Protocol
- Transmission Medium
- Fibre optic
- Max Transfer Distance
- 800 m
- Power
- AC 120/230 V
- 9.7 cm x 12.9 cm x 2.6 cm
- 445 g
- 2-year warranty
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- 3.4 Gbps
- Max Resolution
- 1080p @ 60 Hz
- 800 m
- 1 x HDMI , 1 x - Fibre Channel - SC multi-mode female , 1 x IrDA
- FCC, RoHS
- Power Device
- External power adapter
- Installed Qty
- 2
- Voltage Required
- AC 120/230 V
- 9.7 cm
- 12.9 cm
- 2.6 cm
- 445 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.28 |
StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) | In Stock | £215.80 |
StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) | In Stock | £96.64 |
StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) | In Stock | £359.75 |
StarTech.com HDMI over CAT6 with USB - 50m | In Stock | £183.30 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com 4K 60Hz HDBaseT extender - 70m (100m @ 1080) | In Stock | £435.65 |
StarTech.com HDMI over CAT6 Extender | In Stock | £106.00 |
