HDMI Transmitter and Receiver Kit HDMI 2.0b 7.1 Surround Sound Single and Multimode Fiber. This HDMI over Fiber Extender kit lets you transmit your HDMI audio video signal up to 3300 feet (1000 m) over single-mode fiber, or up to 1000 feet (300 m) over multimode fiber. This converter kit includes both the transmitter and receiver for a complete end-to-end solution.
Astonishing 4K Picture Quality
This HDMI optical extender supports resolutions up to 4K 60Hz (3840 x 2160), providing four times the picture quality of high-definition (1080p). The UHD HDMI Extender supports HDMI 2.0 capabilities, offering 4:4:4 chroma subsampling. This ensures a crystal-clear picture quality and breathtaking color reproduction that is ideal for delivering video content from sources such as Apple TV 4K, Fire TV Stick 4K, or nVidia Shield TV.
Long-Distance Transmission
The Long Range HDMI Extender allows you to extend an HDMI signal up to 3300 feet (1000 m) over single-mode fiber and 1000 feet (300 m) over multimode fiber. Not only is this an incredibly long range solution that can extend an HDMI signal across or between buildings, but because fiber optics transmit data using light rather than copper, it will not cause or be affected by electromagnetic Interference (EMI).
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
ST121HD20FXA is backed by 2-year StarTech.com warranty with free lifetime technical support.
Astonishing 4K picture quality
This HDMI optical extender supports resolutions up to 4K 60Hz (3840 x 2160), providing four times the picture quality of high-definition (1080p). The UHD HDMI Extender supports HDMI 2.0 capabilities, offering 4:4:4 Chroma subsampling. -
Long-distance transmission
- StarTech.com HDMI Over Fiber Extender - HDMI 2.0b - 7.1 Sound - 4K 60Hz - video/audio/infrared/network extender - HDMI
- Video/audio/infrared/network extender
- Form Factor
- External
- Cabling Type
- Fibre optic
- Data Link Protocol
- HDMI
- Transmission Medium
- Fibre optic
- Max Transfer Distance
- 1 km
- Power
- AC 100 - 240 V
- 6.6 cm x 10 cm x 2.6 cm
- 900 g
- 2-year warranty
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- Cabling Type
- Fibre optic
- HDMI
- Max Resolution
- 4096 x 2160 @ 60 Hz
- 1 km
- 7.1 channel audio support, Dolby TrueHD support, DTS-HD Master Audio support, Dolby Atmos support, HDR 4K60 4:4:4 compatible
- 1 x HDMI (input) - 19 pin HDMI Type A female , 1 x (input) - LC single-mode / LC multi-mode female , 1 x IrDA female , 1 x HDMI (output) - 19 pin HDMI Type A female , 1 x (output) - LC single-mode / LC multi-mode female , 1 x IrDA female
- Included Accessories
- IR receiver, IR transmitter, 2 mounting brackets, 2 rubber feet
- Cables Included
- 1 x fibre optic cable - 2.1 m
- FCC, RoHS, WEEE, REACH, HDCP 2.2
- Power Device
- External power adapter
- Installed Qty
- 2
- Voltage Required
- AC 100 - 240 V
- 3 Watt
- 6.6 cm
- 10 cm
- 2.6 cm
- 900 g
- Shipping Width
- 24.8 cm
- Shipping Depth
- 18.3 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 915 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.28 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.75 |
StarTech.com 8-Port 4K 60Hz HDMI Splitter | In Stock | £134.78 |
StarTech.com HDMI Splitter - 2 Port - 4K 60Hz | In Stock | £39.08 |
StarTech.com DP to HDMI Adapter with HDR | In Stock | £25.54 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.81 |
StarTech.com 4K 60Hz HDMI Fiber Extender | In Stock | £492.53 |
