StarTech.com HDMI over CAT6 Extender
Quicklinx: F6TDWS00 Mfr#: ST121HD20V
More than 50 In Stock
£106.00 ex VAT
£127.20 inc VAT
This HDMI over CAT6 extender lets you transmit your 4K 60Hz signal up to 165 ft. (50 m) over a single CAT6 cable. The extender supports High Dynamic Range (HDR), providing high contrast images with enhanced video.
This HDMI Ethernet extender supports a 4K 60Hz (3840 x 2160) resolution, providing four times the picture quality of high-definition (1080p). The extender supports HDMI 2.0 capabilities, offering4:4:4 chroma subsampling. This ensures a crystal-clear picture that's ideal for delivering video content. With HDR support, you can enjoy increased contrast, color brightness and greater luminosity in your images.
Extend an HDMI signal to up to 165 ft. (50 m) with the HDMI to CAT6 converter. Use your existing CAT6 cable infrastructure with a direct connection to the converter for an easy run through walls and ceilings, saving you on installation costs.
Connect your HDMI 2.0 devices and displays with confidence, knowing this extender is HDCP 2.2 compliant. This lets you harness the capabilities of HDMI-enabled devices such as Blu-ray players or online streaming devices in higher resolutions. It is also backward compatible with previous generations of HDMI and HDCP.
StarTech.com HDMI over CAT6 Extender Kit - 4K 60Hz - HDMI Balun Kit - Signal up to 165 ft / 50m - HDR - 4:4:4 - 7.1 Audio Support (ST121HD20V) - video/audio extender - HDMI
Video/audio extender
External
HDMI
Transmission Medium
CAT 6
Max Transfer Distance
50 m
AC 110 - 240 V / DC 12 V
135 g
External
Wired
HDMI
Max Resolution
3840 x 2160 @ 60 Hz
50 m
7.1 channel audio support, HDR 4K60 4:4:4 compatible
1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female , 1 x network - RJ-45 , 1 x management
IR receiver, IR transmitter
FCC, RoHS, WEEE, REACH, HDCP 2.2
External power adapter
Installed Qty
1
135 g
Shipping Weight
155 g
0 - 80% (non-condensing)
F6TD StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £96.64
F6TD StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.03
F6TD StarTech.com 5m 15ft Premium 4K HDMI Cable In Stock £26.32
F6TD StarTech.com 7m 23ft Premium 4K HDMI Cable In Stock £38.23
F6TD StarTech.com HDMI over CAT6 Extender - 4K 60Hz - 330ft / 100m -IR Support In Stock £372.19
