StarTech.com HDMI over Cat5 / Cat6 Receiver for ST424HDBT – 230ft (70m) – 1080p
Quicklinx: 98FVWS00 Mfr#: STHDBTRX
Type: Video Extender
£112.71 ex VAT
£135.25 inc VAT
Extend the HDMI signal from your ST424HDBT Matrix switch over Cat5/Cat6 cable, with IR control. This HDBaseT receiver works with the ST424HDBT HDMI matrix switch to extend an HDMI audio/video source up to 230ft (70m) over Cat5e/6 cabling. One STHDBTRX receiver unit is required for each individual remote display.
Together with the ST424HDBT, the CAT5 HDMI receiver works to create a digital signage solution that eliminates the expense and hassle of running multiple devices with an HDMI matrix switch and extender in one clutter-free system. Because the signal is extended using standard Cat5e/6 Ethernet cables with RJ45 connectors, you can use your existing cabling infrastructure, without the additional cost of special cabling or connectors.
For remote source operation, the HDMI receiver can also extend an Infrared signal from a remote control to operate either the display or the video source from either side or system, using the included IR extender and receiver cables.
StarTech.com HDMI over Cat5 / Cat6 Receiver for ST424HDBT - 230ft (70m) - 4K / 1080p - video/audio/infrared extender
Video/audio/infrared extender
External
Australia, North America, United Kingdom, Europe
Max Transfer Distance
70 m
AC 120/230 V
11 cm x 7.5 cm x 2.35 cm
External
Wired
Max Resolution
1920 x 1200 / 1080p
70 m
Status Indicators
Port status
1 x HDMI , 1 x IrDA , 1 x network - RJ-45
FCC, RoHS
External power adapter
Installed Qty
1
Max Supported Qty
1
AC 120/230 V
11 cm
7.5 cm
2.35 cm
-5 °C
35 °C
5 - 90%
98FV StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.08
98FV StarTech.com HDMI to DVI-D Video Cable Adapter - F/M In Stock £7.46
98FV StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £7.46
98FV StarTech.com 10 ft HDMI to DVI-D Cable - M/M In Stock £8.58
98FV StarTech.com 4x4 HDMI Matrix Switcher / HDMI Extender over Cat5 / Cat6 – 230ft (70m) – 1080p In Stock £1,064.03
98FV StarTech.com HDMI over Cat5 / Cat6 Receiver for ST424HDBT – 230ft (70m) – 1080p In Stock £112.71
Price Range Ex VAT: 100 - 150
