StarTech.com HDMI Over Cat5 / Cat6 Extender with IR - 100 ft (30m) Power Free
Quicklinx: 92Q0WS00 Mfr#: ST121SHD30
Type: Misc
£47.14 ex VAT
£56.56 inc VAT
Extend HDMI up to 100ft (30m) over Cat5e/6 Cabling with Power over Cable to Receiver. The ST121SHD30 HDMI over CAT5e/CAT6 Video Extender kit lets you extend HDMI audio/video and an IR remote control signal by up to 100 feet (30 Meters) over dual Cat5e or Cat6 cable. For added versatility this HDMI extender kit is powered via the HDMI bus, and does not require any additional power adapter.
With support for High-Definition resolutions of up to 1920x1080 / 1080p and the accompanying digital audio, this cost-effective HD extender can easily be installed using new or existing Ethernet infrastructure wiring. Plus, because the extender kit does not require a power adapter, you can easily extend an HDMI signal in areas where access to power outlets is limited.
The HDMI over Cat5e/Cat6 video extender kit includes both the local transmitter and remote receiver units, perfect for point-to-point digital signage applications that require high quality HDMI video. The Extender also works to extend Infrared IR signals from remote controls, perfect for controlling your video source from your video destination.
For additional distance, HDMI cables up to 32-feet (10-meters) in length can be used on the local and remote ends.
StarTech.com HDMI Over Dual CAT5 / CAT6 Extender with Infrared IR 100ft /30m HDMI Over Ethernet Cable Extender Power Free 1080p (ST121SHD30) - video/audio/infrared extender
Video/audio/infrared extender
External
Max Transfer Distance
30 m
4.5 cm x 8.2 cm x 2.2 cm
405 g
External
Wired
Max Resolution
1920 x 1080 / 1080p
30 m
1 x HDMI , 1 x IrDA
FCC, RoHS
4.5 cm
8.2 cm
2.2 cm
405 g
0 - 80%
92Q0 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.26
92Q0 StarTech.com 75 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £21.25
92Q0 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.42
92Q0 StarTech.com HDMI over Cat5 Video Extender with RS232 and IR Control In Stock £308.48
92Q0 StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £50.69
92Q0 StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £167.09
92Q0 StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £90.14
92Q0 StarTech.com HDMI Over Cat5 / Cat6 Extender with IR - 100 ft (30m) Power Free In Stock £47.14
92Q0 StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.15
92Q0 StarTech.com 25 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 25ft Patch Cord In Stock £4.23
Type: Misc
Price Range Ex VAT: 0 - 50
