StarTech.com HDMI or DVI to DisplayPort Active Converter
Quicklinx: 7NYBWS00 Mfr#: HDMI2DP
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Hurry, only 2 left in stock!
£65.59 ex VAT
£78.70 inc VAT
The HDMI2DP DVI or HDMI to DisplayPort Converter converts an HDMI, DVI or Mini DVI input signal into a DisplayPort (or Mini DisplayPort) output, eliminating the cost of upgrading your source device hardware or purchasing a new display. With support for full HD resolutions up to 1920x1200, the HDMI2DP converter is the perfect solution for connecting devices that have an HDMI, DVI single-link or mini DVI output, such as video cards (desktop or laptop), video game consoles or home theater receivers, to your DisplayPort-capable display.
StarTech.com HDMI or DVI to DisplayPort Active Converter - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort output - 20 pin DisplayPort
4.3 cm x 8.2 cm x 2.3 cm
Enclosure Colour
Video converter
Max Resolution
1920 x 1200 at 60 Hz
1 x HDMI input - 19 pin HDMI Type A - female , 1 x DisplayPort output - 20 pin DisplayPort - female
AC 120/230 V
5 Watt
FCC, RoHS
4.3 cm
8.2 cm
2.3 cm
14 g
Enclosure Colour
70 °C
5 - 90% (non-condensing)
7NYB StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £7.46
7NYB StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £7.30
7NYB StarTech.com Mini DVI to HDMI Video Adapter for Macbooks and iMacs- M/F In Stock £12.03
7NYB StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £5.56
7NYB StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
Price Range Ex VAT: 50 - 100
