Record video and audio to your Windows or Mac computer using this USB-C video capture device. This HDMI to USB-C video capture device lets you record HDMI video to your USB-C, USB-A or Thunderbolt 3 computer, and features a durable aluminum enclosure so it can safely travel with your laptop.
For hassle-free recording, you can install the HDMI capture device by simply connecting it to your computer. The capture device features USB Video Class (UVC), a video capture standard that's natively supported by Mac, Windows and Linux . Unlike other capture devices that require proprietary driver installation, UVC based capture devices install automatically for a truly plug-and-play solution. Also, with this capture device you're not limited to the included software. You can use any third-party software that uses UVC compatible frameworks such as Quicktime or DirectShow.
Record 1080p video at 60fps (frames per second), to save your content so it can be shared, stored, or edited. Capture meetings, presentations, conference calls and from security equipment directly to your computer.
Stream your video over the internet using Twitch or other third-party video streaming platforms. With the included software or your own third-party UVC compatible software like Open Broadcaster Software (OBS), you can live broadcast video over the internet using Twitch or other third-party video streaming platforms.
- StarTech.com HDMI to USB C Video Capture Device UVC 1080p 60fps - External USB 3.0 HDMI Audio/Video Capture/Live Streaming - HDMI Recorder (UVCHDCAP) - video capture adapter - USB 3.0
- Video capture adapter
- Interface Type
- USB 3.0
- 6 cm x 9.2 cm x 2.3 cm
- 88 g
- Black, silver
- Video Input
- HDMI input
- Video Modes
- 1080/60p
- Digital Video Format
- MPEG-4, H.264
- Digital Video Capture Speed
- 60 frames per second
- Digital Video Capture Resolution
- 1080p
- Audio Input Support
- Standard
- USB Video class
- OS Required
- Apple MacOS, Linux, Android, Microsoft Windows 7 / 8 / 10
- 2-year warranty
- Interface Type
- USB 3.0
- 6 cm
- 9.2 cm
- 2.3 cm
- 88 g
- Black, silver
Video
- Interface Type
- HDMI input
- Video Modes
- 1080/60p
- MPEG-4, H.264
- 1080p
- Still Image Capture Resolution
- 1080p
- Standard
- USB Video class
- 1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x audio - input - mini-phone stereo 3.5 mm , 1 x USB - SuperSpeed USB 3.0 - 9 pin USB Type B
- Connections
- 1 x SuperSpeed USB 3.0 - 9 pin USB Type B
- Cables Included
- 1 x USB-C to USB-B cable - external , 1 x USB-A to USB-B cable - external , 1 x HDMI cable - external
- Device Features
- USB powered
- FCC, RoHS, WEEE
- TAA Compliant
- OS Required
- Shipping Weight
- 90 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
StarTech.com PCIe HDMI & VGA Capture Card | In Stock | £117.51 |
