Connect your HDMI Micro or HDMI Mini-equipped Smartphone or portable device to your HDMI-capable TV or Display. The HDACDFMM HDMI 2-in-1 T-adapter enables you to use a standard HDMI male-to-male cable to connect your HDMI Micro or HDMI Mini mobile devices, including your Smartphone, Tablet, Digital Camera, etc. to an HDMI-enabled TV or display.
With a Standard HDMI (type A) female connector, an HDMI Mini (type C) male connector, and an HDMI Micro (type D) male connector, you can easily make the necessary conversions and connect to a display, an HDTV or HDMI-capable projector virtually everywhere you go.
The 2-in-1 Multifunction HDMI to Mini or Micro HDMI adapter is a perfect solution for connecting your various mobile devices while avoiding the hassle of having to carry multiple adapters. Plus, the adapter features a compact and lightweight design that fits nicely into any carrying case.
The HDMI T-adapter features high quality, gold-tipped connectors that ensure peak connectivity.
- StarTech.com HDMI 2-in-1 T-Adapter HDMI to HDMI Mini or Micro Combo Adapter - HDMI adapter - 3.16 cm
- Cable
- HDMI adapter
- Length
- 3.16 cm
- Black
- Connectors
- 19 pin mini HDMI Type C - male , 19 pin micro HDMI Type D - male
- Connectors (Second End)
- HDMI - female
- Limited lifetime warranty
- Designed For
- P/N: HDMM30CM
- Cable Type
- HDMI adapter
- Length
- 3.16 cm
- Plated Connector
- Gold
- Black
- Connectors
- 19 pin HDMI Type A - female
- RoHS
- Limited warranty - lifetime
- Designed For
- P/N: HDMM30CM
