Convert and extend a Gigabit Ethernet connection up to 24.8 miles/40 km over Single Mode SC fiber. The ET91000SM402 1000 Mbps Gigabit Single Mode Fiber Media Converter SC (40 km) lets you extend a Gigabit Ethernet network over single mode fiber by up to 40km (25 miles).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the GbE to SM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet to fiber solution, the Ethernet to SC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
- StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps (ET91000SM402) - fibre media converter - GigE
- Fibre media converter - RJ-45 / SC single-mode
- Form Factor
- External
- Localisation
- North America, United Kingdom, Europe
- Cabling Type
- 1000Base-LX, 1000Base-SX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- GigE
- Max Transfer Distance
- 40 km
- Power
- AC 120/230 V
- 9.5 cm x 16 cm x 2 cm
- 0.6 kg
- 2-year warranty
- Designed For
- P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
- Form Factor
- External
- Black
- Localisation
- Connectivity Technology
- Wired
- Cabling Type
- GigE
- 1 Gbps
- 1310 nm
- 40 km
- Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged
- 1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - SC single-mode female x 2
- MTBF
- 65,000 hours
- Plug and Play, FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 9.5 cm
- 16 cm
- 2 cm
- 0.6 kg
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 10 - 90%
- Designed For
StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps | In Stock | £339.30 |
StarTech.com Fiber Media Converter - Open | In Stock | £63.00 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £13.92 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £45.71 |
