StarTech.com Gigabit Ethernet PoE Open SFP Fiber Media Converter – PSE
Quicklinx: 8GTJWS00 Mfr#: ET1110PSE
Power an individual PoE-capable device with this open SFP PSE Media Converter. The ET1110PSE PSE/PoE Media Converter, which features an open SFP slot, enables you to create an Ethernet-Fiber link by transparently converting from 1000Base-SX/LX fiber to 10/100/1000Base-T, while acting as a Power Sourcing Equipment (PSE) device.
With the added flexibility of an open SFP slot, the media converter enables you to choose the Gigabit SFP that best suits your network fiber connection and distance requirements.
Capable of delivering up to 48V DC power to IEEE 802.3af devices (such as wireless access points (WAP) or IP cameras), using standard Cat 5 (or better) cabling, this PoE media converter offers the ideal solution for providing data and power to areas where electrical wall outlets may not be available - a versatile solution that saves the hassle and expense of running new electrical wiring.
StarTech.com Gigabit Ethernet PoE Open SFP Fiber Media Converter - PSE - fibre media converter - 10Mb LAN, 100Mb LAN, GigE
Fibre media converter - RJ-45 / SFP (mini-GBIC)
External
Cabling Type
10Base-T, 1000Base-SX, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
Power Over Ethernet (PoE)
PoE
AC 120/230 V
6.5 cm x 14.5 cm x 3.5 cm
0.6 kg
P/N: GLCSXMMRGDST, J4858C10PKST, J4858CST
External
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Port transmission speed, port duplex mode, power, link/activity
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
1 x network - RJ-45 , 1 x - SFP (mini-GBIC)
FCC, RoHS
PoE
External power adapter
AC 120/230 V
5 Watt
Power Provided
15.4 Watt
6.5 cm
14.5 cm
3.5 cm
0.6 kg
50 °C
10 - 90% (non-condensing)
8GTJ StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £43.94
