StarTech.com Gigabit Ethernet over Coaxial Unmanaged Network Extender Kit - 2.4km
Quicklinx: 8GTHWS00 Mfr#: EOC1110K
Type: Media Converter
£235.20 ex VAT
£282.24 inc VAT
Extend an Ethernet network over Coaxial cable up to 1.5 miles (2.4km). The EOC1110K Gigabit Ethernet over Coaxial Unmanaged LAN Extender Kit (2.4km) includes both end points, and allows you to span a 10/100/1000Mbps Ethernet network over extremely long distances (up to 2.4 km/1.5 mi) while still maintaining high-speed network connectivity.
The coax Ethernet extender allows you to run the connection over existing coaxial cable, with little to no modification required, making it a perfect solution for a broad range of applications, including connecting isolated user stations from the same or separate building, or overcoming infrastructure obstacles and distances (e.g. older stone/concrete architecture) where new wiring or wireless connectivity may be impossible.
The gigabit Ethernet over coax kit helps to eliminate expense by allowing CCD or CATV video and Ethernet network data to share the same coaxial cable without interference.
StarTech.com Gigabit Ethernet over Coaxial Unmanaged Network Extender Kit - short-haul modem - GigE
Short-haul modem - RJ-45 / F connector
External
Cabling Type
10Base-T, 100Base-TX, 1000Base-T, Coax
GigE
Max Transfer Distance
2.4 km
AC 120/230 V
13.8 cm x 28 cm x 7.7 cm
300 g
Short-haul modem
External
Wired
Cabling Type
GigE
2.4 km
Status Indicators
Power, link/activity
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
1 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 female , 2 x network - F connector
FCC, RoHS
External power adapter
AC 120/230 V
4 Watt
13.8 cm
28 cm
7.7 cm
300 g
50 °C
10 - 90%
8GTH StarTech.com 25 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £5.09
8GTH StarTech.com 15 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £3.80
8GTH StarTech.com 10 ft Cat5e Gray Molded RJ45 UTP Cat 5e Patch Cable In Stock £3.21
8GTH StarTech.com 15 ft Cat5e Black Molded RJ45 UTP Cat 5e Patch Cable In Stock £3.69
8GTH StarTech.com Gigabit Ethernet over Coaxial Unmanaged Network Extender Kit - 2.4km In Stock £235.20
Price Range Ex VAT: 150 - 300
