Extend an Ethernet network over Coaxial cable up to 1.5 miles (2.4km) - Receiver only. The EOC1110R Gigabit Ethernet Over Coaxial LAN Extender Receiver (2.4km) is an additional receiver that can be used with the EOC1110K to create a point-to-multipoint topology, allowing you to span a Gigabit network over extremely long distances (up to 2.4 km) while still maintaining high speed network connectivity.
The device allows you to run the connection over existing coaxial cable with little to no modification required, making it a perfect solution for a broad range of applications, including connecting isolated user stations from within the same building or from a separate building, or overcoming infrastructure obstacles and distances (e.g. older stone/concrete architecture) where new wiring or wireless may be impossible.
When coupled with the EOC1110K Coaxial Ethernet Extender Kit, the Coaxial Ethernet LAN Extender Receiver helps to eliminate expense by allowing video streaming and data to share the same coax cable without interference.
- StarTech.com Gigabit Ethernet over Coaxial LAN Extender Receiver 2.4 km (1.5 mi) - IP to Coax Converter - Ethernet over RG6 Coax Receiver (EOC1110R) - short-haul modem - GigE
- Short-haul modem (receiver) - RJ-45 / F connector
- Form Factor
- External
- Localisation
- North America, United Kingdom, Europe
- Cabling Type
- 1000Base-T
- Data Transfer Rate
- 112 Mbps
- Data Link Protocol
- GigE
- Transmission Medium
- Coax
- Max Transfer Distance
- 2.4 km
- Power
- AC 100/230 V
- 28 cm x 13.9 cm x 7.7 cm
- 0.3 kg
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Form Factor
- External
- Black
- Localisation
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-T
- GigE
- 112 Mbps
- 2.4 km
- Status Indicators
- Power, link OK, LAN, link/activity
- Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
- HomePNA, IEEE 802.3ab
- 2 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 female , 2 x aerial - F connector female
- MTBF
- 57,000 hours
- Plug and Play, FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 100/230 V
- 4 Watt
- 28 cm
- 13.9 cm
- 7.7 cm
- 0.3 kg
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 10 - 90%
- Designed For
