StarTech.com Gigabit Ethernet Over Coaxial LAN Extender Receiver - 2.4 km
Quicklinx: 8K0BWS00 Mfr#: EOC1110R
Extend an Ethernet network over Coaxial cable up to 1.5 miles (2.4km) - Receiver only. The EOC1110R Gigabit Ethernet Over Coaxial LAN Extender Receiver (2.4km) is an additional receiver that can be used with the EOC1110K to create a point-to-multipoint topology, allowing you to span a Gigabit network over extremely long distances (up to 2.4 km) while still maintaining high speed network connectivity.
The device allows you to run the connection over existing coaxial cable with little to no modification required, making it a perfect solution for a broad range of applications, including connecting isolated user stations from within the same building or from a separate building, or overcoming infrastructure obstacles and distances (e.g. older stone/concrete architecture) where new wiring or wireless may be impossible.
When coupled with the EOC1110K Coaxial Ethernet Extender Kit, the Coaxial Ethernet LAN Extender Receiver helps to eliminate expense by allowing video streaming and data to share the same coax cable without interference.
StarTech.com Gigabit Ethernet over Coaxial LAN Extender Receiver 2.4 km (1.5 mi) - IP to Coax Converter - Ethernet over RG6 Coax Receiver (EOC1110R) - short-haul modem - GigE
Short-haul modem (receiver) - RJ-45 / F connector
External
North America, United Kingdom, Europe
Cabling Type
1000Base-T
Data Transfer Rate
112 Mbps
GigE
Transmission Medium
Coax
Max Transfer Distance
2.4 km
AC 100/230 V
28 cm x 13.9 cm x 7.7 cm
0.3 kg
P/N: SVA12M2NEUA, SVA12M5NA
External
Wired
Cabling Type
1000Base-T
GigE
Data Transfer Rate
112 Mbps
2.4 km
Status Indicators
Power, link OK, LAN, link/activity
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
HomePNA, IEEE 802.3ab
2 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 female , 2 x aerial - F connector female
MTBF
57,000 hours
Plug and Play, FCC, RoHS
External power adapter
AC 100/230 V
4 Watt
28 cm
13.9 cm
7.7 cm
0.3 kg
50 °C
10 - 90%
