Product
Brand
StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps
Quicklinx: 85DJWS00 Mfr#: ET91000SC2
Type: Media Converter
£115.23 ex VAT
£138.27 inc VAT
Convert and extend a Gigabit Ethernet connection up to 550 m / 1804 ft over Multi Mode SC fiber. The ET91000SC2 1000 Mbps Gigabit Multimode Fiber Media Converter (SC, 550m) lets you extend a Gigabit Ethernet network over multimode fiber, at distances up to 550m (1804 ft).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the GbE to MM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet to fiber solution, this Ethernet to SC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, the fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
StarTech.com Gigabit Ethernet MM Fiber Media Converter SC 550m - fibre media converter - GigE
Fibre media converter - RJ-45 / SC multi-mode
External
North America, United Kingdom, Europe
Cabling Type
1000Base-LX, 1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
AC 120/230 V
9.5 cm x 16 cm x 2 cm
0.62 kg
2 years warranty
External
Wired
Cabling Type
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - SC multi-mode female x 2
MTBF
65,000 hours
Plug and Play, FCC, RoHS
External power adapter
AC 120/230 V
9.5 cm
16 cm
2 cm
0.62 kg
60 °C
10 - 90%
85DJ StarTech.com 15 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £4.51
85DJ StarTech.com 10 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.87
85DJ StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps In Stock £115.23
Price Range Ex VAT: 100 - 150
