StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot
Quicklinx: 93WKWS00 Mfr#: ET91000SFP2
Type: Media Converter
15 in stock
£100.65 ex VAT
£120.78 inc VAT
Convert and extend a Gigabit Ethernet connection over fiber using the Gigabit SFP of your choice. The ET91000SFP2 Open SFP Fiber Media Converter converts and extends a Gigabit Ethernet connection over fiber, using the Gigabit SFP of your choice.
A versatile solution for connecting an Ethernet (1000Base-T) network to remote network segments over a fiber backbone, the media converter features an open SFP slot that lets you choose the MSA-Compliant Gigabit SFP that best suits your fiber connection mode (single / multi-mode) and distance requirements.
The fiber to Ethernet converter has a durable all-steel chassis and offers simple plug-and-play installation, while support for full-duplex operation and Jumbo Frame support provides efficient network operation.
For added versatility, this Gigabit media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U). For applications where multiple chassis-mounted media converters are required, this Gigabit media converter can be purchased as a Card Module only (ET91000SFP2C).
StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot - Fiber to Ethernet Converter - Gigabit Ethernet Media Converter (ET91000SFP2) - fibre media converter - 100Mb LAN, GigE
Fibre media converter - RJ-45 / SFP (mini-GBIC)
External
Cabling Type
1000Base-SX, 100Base-LX, 1000Base-T
Data Transfer Rate
1.25 Gbps
100Mb LAN, GigE
9.5 cm x 2 cm x 16 cm
400 g
P/N: GLCSXMMRGDST, J4858C10PKST, J4858CST, SVA12M2NEUA, SVA12M5NA
External
Wired
Cabling Type
100Mb LAN, GigE
Data Transfer Rate
1.25 Gbps
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, Jumbo Frames support
IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45 , 1 x Ethernet 1000 - SFP
MTBF
65,000 hour(s)
FCC, RoHS, MSA
9.5 cm
2 cm
16 cm
400 g
60 °C
10 - 90% (non-condensing)
93WK StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £41.04
93WK StarTech.com 10/100 Mbps Ethernet Single Mode WDM Fiber Media Converter Kit SC 20km In Stock £236.35
93WK StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m In Stock £129.09
93WK StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps In Stock £116.66
93WK StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps In Stock £309.28
93WK StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £33.30
93WK StarTech.com 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Fiber Media Converter In Stock £488.43
93WK StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £35.65
93WK StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC – 10 km (Mini-GBIC) In Stock £39.20
93WK StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot In Stock £100.65
93WK StarTech.com Gigabit Ethernet Fiber Media Converter Card Module with Open SFP Slot In Stock £93.38
Price Range Ex VAT: 100 - 150
