Convert and extend a Gigabit Ethernet connection over fiber using the Gigabit SFP of your choice. The ET91000SFP2 Open SFP Fiber Media Converter converts and extends a Gigabit Ethernet connection over fiber, using the Gigabit SFP of your choice.
A versatile solution for connecting an Ethernet (1000Base-T) network to remote network segments over a fiber backbone, the media converter features an open SFP slot that lets you choose the MSA-Compliant Gigabit SFP that best suits your fiber connection mode (single / multi-mode) and distance requirements.
The fiber to Ethernet converter has a durable all-steel chassis and offers simple plug-and-play installation, while support for full-duplex operation and Jumbo Frame support provides efficient network operation.
For added versatility, this Gigabit media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U). For applications where multiple chassis-mounted media converters are required, this Gigabit media converter can be purchased as a Card Module only (ET91000SFP2C).
- StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot - Fiber to Ethernet Converter - Gigabit Ethernet Media Converter (ET91000SFP2) - fibre media converter - 100Mb LAN, 1GbE
- Fibre media converter - RJ-45 / SFP (mini-GBIC)
- Form Factor
- External
- Cabling Type
- 1000Base-SX, 100Base-LX, 1000Base-T
- Data Transfer Rate
- 1.25 Gbps
- Data Link Protocol
- 100Mb LAN, 1GbE
- 9.5 cm x 2 cm x 16 cm
- 400 g
- 2-year warranty
- Designed For
- P/N: GLCSXMMRGDST, J4858C10PKST, J4858CST, SVA12M2NEUA, SVA12M5NA
- Form Factor
- External
- Connectivity Technology
- Wired
- Cabling Type
- 100Mb LAN, 1GbE
- 1.25 Gbps
- Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, Jumbo Frames support
- IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x Ethernet 1000 - SFP
- MTBF
- 65,000 hour(s)
- FCC, RoHS, MSA
- 9.5 cm
- 2 cm
- 16 cm
- 400 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 10 - 90% (non-condensing)
- Designed For
