StarTech.com GbE Fiber Media Converter 20km
Quicklinx: C53KWS00 Mfr#: ET91000SM20
13 in stock
£168.93 ex VAT
£202.71 inc VAT
Convert and extend a Gigabit Ethernet connection up to 20 km (12.4 mi) using single-mode LC fiber cable. This Gigabit Ethernet to fiber media converter is a cost-effective way to extend your network, or extend the distance between two devices by up to 20 km (12.4 mi.).
Fiber network connections provide greater distance and security, with less electromagnetic interference (EMI) than typical RJ45 copper-based networks, making it perfect for IT professionals and secure setups in government, business, or educational applications.
This versatile copper-to-fiber converter supports standalone operation, or alternatively it can be installed into the StarTech.com ETCHS2U Rackmount Chassis (ETCHS2U - sold separately), giving you more options for integration into your existing network. The card module can also be inserted back into the ET91000SM20 enclosure, plus it's compatible with enclosures from other StarTech.com ET91000 series media converters (sold separately).
The converter features a pre-installed Gigabit SFP transceiver with LC connectors. Should your network infrastructure change in the future, you can easily swap and replace the module to adapt the media converter to your new network requirements.
With flexible integration and connectivity up to 20 km away, you can provide network access to remote areas in other buildings, or in areas where Wi-Fi is unreliable or unavailable.
This heavy-duty fiber media converter is designed for maximum reliability. It features a metal (steel) enclosure, so it can withstand the demands of harsh environments such as factories or warehouses.
Plus, by relying on this more durable fiber media converter, you can reduce the strain on your existing copper-based network equipment and potentially extend the life of those devices, which helps save future expenses.
This high-performance media converter supports a range of network setup and diagnostic protocols (for example, Link Fault Passthrough, Auto Laser Shutdown (ALS), and Auto MDIX, so you can set up and troubleshoot your network easily.
If your existing network consists of RJ45 copper-based devices and cables, you might not be ready for future network expansion. Because the newest fiber-based network switches feature SFP ports more often than RJ45 ports, you might need a converter to bridge your copper and fiber networks together.
StarTech.com Singlemode (SM) LC Fiber Media Converter for 1Gbe Network - 20km - Gigabit Ethernet - 1310nm - with SFP Transceiver (ET91000SM20) - fibre media converter - GigE
Fibre media converter - RJ-45 / LC single-mode
External
Australia, North America, United Kingdom, Europe
Cabling Type
1000Base-LX, 1000Base-T
Data Transfer Rate
2 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
20 km
AC 120/230 V / DC 12 V
8.8 cm x 15.9 cm x 2.3 cm
410 g
P/N: SVA12M2NEUA, SVA12M5NA
External
Wired
Cabling Type
GigE
Data Transfer Rate
2 Gbps
Optical Wave Length
1310 nm
20 km
Status Indicators
Power, link/activity
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, Jumbo Frames support, rugged
IEEE 802.3z, IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX - LC single-mode female x 2
MTBF
65,000 hours
FCC, RoHS, WEEE, RCM
External power adapter
8.8 cm
15.9 cm
2.3 cm
410 g
50 °C
10 - 90% (non-condensing)
C53K StarTech.com 1000 Mbps Gigabit Single Mode Fiber Media Converter LC 40 km In Stock £277.70
C53K StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m In Stock £127.49
C53K StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot In Stock £99.41
C53K StarTech.com Gigabit Ethernet Fiber Media Converter Card Module with Open SFP Slot In Stock £92.23
C53K StarTech.com OAM Managed Gigabit Ethernet Fiber Media Converter - MM LC 550m - 802.3ah Compliant In Stock £153.06
C53K StarTech.com GbE Fiber Media Converter 10km In Stock £182.38
C53K StarTech.com GbE Fiber Media Converter 20km In Stock £168.93
C53K StarTech.com 10GbE Fiber Media Converter In Stock £835.11
Price Range Ex VAT: 150 - 300
