StarTech.com Gb RJ45 SFP - HP Compatible
Quicklinx: C581WS00 Mfr#: J8177CST
22 in stock
£32.28 ex VAT
£38.73 inc VAT
Ensure reliable and cost-efficient Gigabit Ethernet connections with this RJ45 Mini-GBIC module. This HP compatible Gigabit Copper SFP is engineered by StarTech.com to deliver what you need most in your network connections: reliability. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality SFP transceiver module can be installed into HP networking devices that support the J8177C SFP transceiver module, as well as other major brands of networking equipment.
The RJ45 1000Base-T SFP delivers Gigabit connectivity over a distance of up to 100 m (328 ft.). It provides a dependable and cost-effective way to add, replace or upgrade a copper Ethernet port on your networking equipment. For large-scale requirements and maximum cost savings, this RJ45 copper SFP is also available in a J8177C10PKST" text="10-pack: J8177C10PKST.
This Gigabit RJ45 SFP is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This Gigabit Copper SFP is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP J8177C SFP transceiver. The StarTech.com transceiver is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this SFP is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and convenient solution that's compatible with a wide range of multi- and single-port Gigabit Ethernet networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFP provides dependable performance, enabling you to expand your network to remote segments cost-effectively. The SFP supports autonegotiation, a maximum distance of up to 100 m (328 ft.), and maximum data rates of up to 1000Mbps.
StarTech.com HP J8177C Compatible SFP Transceiver Module - 1000BASE-T RJ45 Copper Transceiver (J8177CST) - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - RJ-45 / SFP (mini-GBIC)
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
GigE
Max Transfer Distance
100 m
HP J8177C
1.4 cm x 6.8 cm x 1.4 cm
25 g
HP Switch 2610-24, Switch 2610-24/12, Switch 2610-48; HPE 1810, 1910, 20p 10/100/1000, 2610, 3500, 6200, Switch 53XX, Switch 5406, Switch 8212, Switch gl 10/100/1000, Switch gl Mini-GBIC Module, Switch vl 4-port, Switch xl Mini-GBIC Module, vl 20; HPE Aruba 2530, 5406, Switch 5400zl 24
Plug-in module
Silver
Wired
Cabling Type
1000Base-T
GigE
Data Transfer Rate
1 Gbps
100 m
Auto-negotiation, auto-uplink (auto MDI/MDI-X)
IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45 female
FCC, RoHS, MSA
HP J8177C
1.4 cm
6.8 cm
1.4 cm
25 g
Limited warranty - lifetime
70 °C
30 - 75%
HP Switch 2610-24, Switch 2610-24/12-PWR, Switch 2610-24-PWR, Switch 2610-48, Switch 2610-48-PWR, Switch 5406zl-48G Intelligent Edge, Switch 5412zl Intelligent Edge, Switch 5412zl-96G Intelligent Edge , HPE 1810-24 v2, 1810-8 v2, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 20p 10/100/1000 + 4p Mini-GBIC Module, 2610-24 Switch, 2610-24-PoE Switch, 2610-24-PPoE Switch, 2610-48 Switch, 2610-48-PoE Switch, 3500-24G-PoE yl Switch, 3500-48G-PoE yl Switch, 6200-24G-mGBIC yl Switch, Switch 5348xl, Switch 5372xl, Switch 5406zl Intelligent Edge, Switch 8212zl, Switch gl 10/100/1000 Module, Switch gl Mini-GBIC Module, Switch vl 4-port Mini-GBIC Module, Switch xl Mini-GBIC Module, vl 20p Gig-T+ 4P SFP module switch , HPE Aruba 2530-24G, 2530-24G-PoE+, 2530-48G, 2530-48G-PoE+, 2530-48-PoE+, 5406 zl, Switch 5400zl 24p Mini-GBIC Module
C581 StarTech.com SFP - HP J4858C Comp. 10 Pack In Stock £230.93
C581 StarTech.com SFP - HP J4859C Comp. 10 Pack In Stock £266.18
C581 StarTech.com HP Compatible RJ45 SFP 10 Pack In Stock £248.97
C581 StarTech.com Gb RJ45 SFP - HP Compatible In Stock £32.28
C581 StarTech.com SFP+ - HP JD092B Compatible In Stock £37.11
C581 StarTech.com SFP+ - HP J9150A Compatible In Stock £32.51
C581 StarTech.com SFP - HP J4859C Compatible In Stock £32.28
C581 StarTech.com Gb Copper SFP HP 453154-B21 Compatible In Stock £123.62
Price Range Ex VAT: 0 - 50
